Massive storm clean up
/ Massive storm clean up
If that is a rental, I would think the repair cost should be on the rental company. I would think everyone that has ever rented that machine has contributed to that failure along the way. Not right that it just happened to fail during your rental time.
Thats the way they are handling it.
/ Massive storm clean up #142
Huge difference between the area you cleaned up and the area with the downed trees. The area with the downed trees is painful to look at.
It really is. The clock is now ticking on the area with the downed trees. I know that beech trees are pretty much junk after about 1 year. They do not store well and there are quite a few beech trees in there. Also there are several already-dead ash trees.
Pretty soon that area will turn to junk. Would like to get in there and start pulling trees out.
/ Massive storm clean up #144
Watch it start raining, hopefully after the next cutting of hay but hauling those logs out on those freshly disturbed (mud) slopes will be skidder work.
That's presuming the trucks are in the bottom land and not up hill.😖
We got a few loads of logs hauled when it was dry.
A new issue is developing: What to do with the “cut offs” or “stubs” of the logs which are trimmed for length to fit on log truck. Many are 3-5’ long. Some are 3’+ in diameter.
I think the owner may be OK with scattering them around on the property. Might be a way for me to use the dump truck to make a little more money.
/ Massive storm clean up #146
Does anyone you know need firewood? Load them up and deliver them for maybe $100 a load. You won’t make much at that but at least you covered fuel and got the job done.
It’s all pine, so no good for firewood.
/ Massive storm clean up #148
Burning them is not an option?
Any ideas for making them decompose together in a single pile more quickly? Scattering them would seem to just junk up more area unless there are some gulley areas washing out where they could be used to stop erosion.
/ Massive storm clean up #149
On my own property, I use a few larger logs to make a base for a wildlife brush pile, then throw slash over the top of it. It makes for great wildlife habitat, and contains what we humans think of as a "mess" into a few smaller areas, rather than leving it scattered all over the place.
A lot of landowners are interested in wildife and creating habitat, but have a hard time understanding that wildlife likes it messy. They spend a lot of time making their forest and yard look like a park, then wonder why they see such a narrow sampling of wildlife species. Some of them get more comfortable with the idea once they understand that the mess has a purpose.
EDIT: added this old file I had kicking around about building brush piles for wildlife. They recommend starting with more durable species than Pine, but anything will work, it just doesn't last as long as more rot resistant species.
  • Brush Piles MD Ext.pdf
/ Massive storm clean up #150
Based on this research, my post about making one neat tidy pile is absolutely the wrong thing to do if they want the wildlife habitat to recover.
2022 FORD F-150 XLT CREW CAB TRUCK (A59823)
2022 FORD F-150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1009 (A61166)
1009 (A61166)
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2020 John Deere 6105E (A60462)
2020 John Deere...
2022 Ram 2500 (A55973)
