Manual tire changer help
/ Manual tire changer help #21
/ Manual tire changer help #22
I did many tires while working at Sears Automotive center during college.. we had the fancy machines, but the boss explained to the new guys all the time, that just means you can mess up a custom rim very fast without any effort. We hated the fancy rims, there was risk of problems at every turn...
Never had a bar with the wheels, but my guess would be the wheels ride the rim, not the tire bead;
No- the hook slides on the outside of the rims lip
The wheel rolls on the tires inner bead as the bar is pulled against the tire machines center post .
When working correctly the bead slips over the rim behind the wheel as the bar is moved around the wheel
If I get a chance I will take a few pictures of my changer with the bar putting a bead on.
ps. Here is a place you can get a parts/operation manual for the old Coats machines- Very helpful...
Coats Tire Changer parts Manuals
Page 3 of the 510 manual shows the mounting procedure using the bar in question (although the manual itself is upside down) that should clear up some things
Thanks for the link. Even though it's upside down, I can see the procedure for mounting. They actually have the tire bead inbetween the hook and the wheel on the bar. I will have to try that. Thanks!
P.S. I thought I had put this in the wrong forum on this board, but I am getting a lot of responses and help with this. Thank you.
/ Manual tire changer help #24
will be putting on a new set of tires in the next few days for my nephews rig- so will try and get a couple pictures of the bead going on
/ Manual tire changer help #25
Sorry it took so long some pictures of the manual machine and bar in use: bottom bead being put on
Now the easier to see top bead
hope this clears up how the bar and roller get the bead on the wheel
/ Manual tire changer help #26
Rats! Guess I will have to stop using the MoJo lever to mount my F150 tires.
prs
/ Manual tire changer help #27
Very nice pics, very clear to see.
prs
/ Manual tire changer help #28
prs
Hey what ever works for you, The old coats machine and it's bar get it done for me .
Hoping they will work for the OP to, It's all good :thumbsup:
/ Manual tire changer help #29
Get a high lift jack - from TSC to break bead - some tire irons and a cheetah to set beed when airing up - I thinks its faster that the manual tire things -
Godwin Pump (A59228)
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
2016 FORD TRANSIT 350 CARGO VAN (A59905)
2016 FORD TRANSIT...
