Mantis tiller vs Stihl yard boss
/ Mantis tiller vs Stihl yard boss #1
waystd
New York
'99 kubota L3010 w/La481 fel
I am looking into buying small tiller. Mantis vs. Stihl yardboss. 2 or 4 cycle does not matter. Looking for the better machine.Price does not matter cuz
they are pretty close. Any thoughts on these two machines for quality.
Thank you.
/ Mantis tiller vs Stihl yard boss #2
I have the Mantis 2 stroke tiller with a couple attachments. It always starts, always runs good, I wear ear plugs usually. I have no complaints about mine. I did get the kickstand and really like it. I also purchased these little plastic anti-wrap "donuts" (for the two drive axles/shafts) and they work good also.
/ Mantis tiller vs Stihl yard boss #3
I also have a Mantis 2 stroke. I have not had a chance to use it a ton but seems to work great so far. My research found people liked the Mantis better than any of the others, people said it was more heavy duty.
/ Mantis tiller vs Stihl yard boss #4
Never used the Stihl (but love Stihl tools) but have a Mantis and used it quite a bit. It works great for small areas, and I have never had a problem with it. Too bad you can't try one out before buying. The Mantis is well designed for digging and mixing beds. I works in a push/pull motion, and I often use the back "blade" to pull dirt into a pile or move it around.
Thanks for the responses. As a matter of fact HCJTractor, i called my local
rental place and found they do rent out the mantis. Don't know if they have the 2 or 4 stroke but at least they rent them. It will give me an opportunity
to try one, which will be nice before i buy. Thanks again.
/ Mantis tiller vs Stihl yard boss #6
Years ago I had a couple of mantis tillers till it died. They were good machines, worked fine till they went bad for different reasons.
We sell the stihls and I have used them a bit and they are a nice machine.
/ Mantis tiller vs Stihl yard boss #7
To contrast, I am not that fond of the Mantis. Maybe it's just me, but mine was always a pain to get started and keep running. :confused:
Gave mine to my brother and bought a Honda tiller at Home Depot (I think). Wow!! Now THAT's a performer!! It sat for almost three years till I decided to fire it up again this spring. Fearing the worst, since it had gas in the tank from who knows when, I went through the startup procedure, and voila`, second pull - away it went. :) Excellent unit.
/ Mantis tiller vs Stihl yard boss #8
I have the 2 stroke Mantis with kick stand, dethatcher, aerator, and edger, besides the tilling blades. I tried the edger, but decided I'd rather just use my string trimmer for edging. I've never even used it as a tiller.:D I bought it primarily for the dethatcher and I use that and the aerator. I would NOT want one without the kickstand. The only problem I've had with it is (1) the fuel filter in the tank can get clogged or hardened and not allow fuel flow, and (2) the carburetor can get out of adjustment. Since I've learned how to quickly correct those 2 things, no other "malfunction". The placement of the on/off switch is such that I've accidentally bumped it and killed the engine a few times.
So I like the Mantis. I would expect the Stihl to be good also, but I've only seen them at the dealer; never used one, never seen one used.
/ Mantis tiller vs Stihl yard boss #9
When mine wouldn't start, it was frustrating for awhile, but then I found the problem to be the fuel filter. I have a new filter, but have never used it. I just give the original one a quick shot of compressed air in the reverse direction and it's ready to go again. And when it wouldn't keep running, I finally learned how to adjust the carburetor.:D
/ Mantis tiller vs Stihl yard boss #10
I have a Mantis 2 stroke.
Always starts and runs good, never had a problem.
/ Mantis tiller vs Stihl yard boss #11
I would never have bought the Mantis if they hadn't advertised a full money back satisfaction guaranteed deal. And I also called on the phone at the time and ordered a reconditioned (or did they call it "reburbished") one at a discount. It all sure looked new to me. With their money back deal, I figured they'd have a number of reconditioned ones on hand, but nope, I had to wait a couple of weeks for them to get one, so I guess most of the folks who buy them, keep them.
That's something I hadn't even heard of, so I just now went to their website and guess you're talking about the "weed reducers" and I ordered a pair.:rolleyes:
/ Mantis tiller vs Stihl yard boss #12
Hi Bird; That is correct, "weed reducers". I couldn't remember the name, so that was my best description. I think you'll like them. I only learned about the kickstand and these weed reducers from the little catalog that came in the box with the new tiller some years ago.
/ Mantis tiller vs Stihl yard boss #13
I don't mean this obnoxiously, but I don't understand the role of the mantis? Seems like either a real rototiller like a gravely or tractor is called for, or a hoe would be easier. I actually use a hoe a lot - the design is time tested.
It seems like the amount of effort required to get the mantis to rototill would be worse than hoeing?
/ Mantis tiller vs Stihl yard boss #14
I also have a Mantis, have had it for 20 yrs or so. It has a 2-stroke Echo engine. Always starts, really light, only use it in the spring and the fall in our little garden.
For a small plot it's ideal for tilling-- and it can be held stationary for some real chewing/digging action if necessary. Never had any problems starting it- amazing!
I figure that's its main claim to fame; for a small garden it's just really convenient- grab it from its hanging spot, add a little fuel, crank it up, 20-30 minutes tilling, remove, rinse off & oil-coat tines, back into storage.
I agree about the switch, however-- I've hit it a number of times as well!
/ Mantis tiller vs Stihl yard boss #15
Well, you're sure right about the hoe being time tested . . . and I hated using one 60 years ago almost as much as I do today.:D I'd have never bought the Mantis if I still lived out in the country, had a tractor, a big vegetable garden, etc. But for a dethatcher (power rake) and aerator on a small lawn, it's quite handy, because you see I dislke manual dethatchers and rakes almost as much as the hoe.:D
/ Mantis tiller vs Stihl yard boss #16
Think of the Mantis as a power hoe. I think its about the same effort for the hoe as the Mantis, maybe a little less for the Mantis. I don't have to bend over so much. It is a lot faster and if you have a large garden its a big help. You still will need to hoe between the plants, but it takes care of 90% of the weeds very quickly.
/ Mantis tiller vs Stihl yard boss #17
I'm glad to see this thread because I'm seriously considering buying a Mantis. I didn't even know there was a Stihl alternative.
I think a mini tiller like the Mantis is the perfect compliment to my tractor mounted tiller. If I have large areas to till, I use the 4' tiller on the tractor. Mid season I could use the Mantis between rows to cut down on weeding time. I used to plant the rows far enough apart to get my walk-behind tiller between them, but the walk-behind is now scrap metal, and it would be nice to have the rows closer together.
People must love the Mantis tillers, though, because I been looking for a used one for a few years now, and I've only seen one. That one was sold before I could even make the phone call.
/ Mantis tiller vs Stihl yard boss #18
I don't know what kind of prices used ones sell for, if you can find one, but I just looked at the paperwork on mine. It's 2 years old (was shipped on 6/29/07) and they called it a "slighly used refurbished" 2 stroke and by ordering factory direct, it was $90 less than a new one, but came with the same one year money back guarantee as a new one. And of course, I wouldn't have been able to tell it from a new one.
/ Mantis tiller vs Stihl yard boss #19
We have a Mantis tiller,honda 4 stroke,it starts second pull every time.coobie
/ Mantis tiller vs Stihl yard boss #20
I see that they now have a corded electric model for the same price as the 2 stroke, $349, and the 4 stroke is a hundred dollars more.
