Making electrical wire longer
/ Making electrical wire longer #1
3Ts
Elite Member
East Texas
Case, Kubota, John Deere
I need to reroute an electrical conduit and will end up making it 2 or 3 feet longer. I hate to replace 4 wires that are 65' long with ones that are 68' long. Is it legal (as in code compliant) to use a crimper to join 2 wires in a butt splice if they are inside a conduit? Amazon has a 10 ton barrel crimper that I would use and these wires are #2 THHN. The splices would be staggered so they're not all in the same place in the conduit.
Note: To replace the wire is about $1k, the crimper and splice barrels are about $50 which is what prompts this question.
/ Making electrical wire longer #3
I agree just add a splice ready conduit box or a junction box.
I would not have a splice in the conduit itself.
/ Making electrical wire longer #4
As far as I know it has to be in a box. Unless this will work?
/ Making electrical wire longer #5
There has to be some place on that 65 foot run where an outlet box would be useful. Closer to one end or the other would be nice (save on wire). But, Do it right! Use a box and wire nuts if nothing else.
Heck! Put in TWO outlet boxes "somewhere" . A good layout might not waste much wire at all, and provide some convenience.
/ Making electrical wire longer #6
He's talking about 2 AWG THHN. Gonna be pretty tough getting that wrapped around the terminals on an outlet. ;)
/ Making electrical wire longer #9
NEC requires splices to be in a box.... Just use wire nuts and appropriate box.....
I'm not sure you can use wire nuts on 2 AWG THHN proper connection would be a butt splice crimp connection.
/ Making electrical wire longer #10
Not allowed, use a box.
/ Making electrical wire longer #14
If its not a driveway, you can use simple bury boxes.
Those boxes shown in the first attachment / two images are solid, but the green one is for irrigation only.
You might want to check code requirements on these direct burial boxes, first to see if they're only for pass-thru and service loops, and second to see what type of splicing hardware is allowed if they are used for splicing.
I have two direct burial boxes, the same model as that beige one shown in the top right of @grsthegreat's image, one for low voltage and the other is line voltage. They were installed under prior ownership, and the prior guy was very not DIY, he had pro's do 100% of the work on this house. But the splices all corroded pretty badly over the course of 20 years.
Whatever electrician set the boxes just had them in dirt, and did a terrible job with the install overall. Inside was a total rat's nest, and the boxes were both cock-eyed and full of mud. So I dug them out, dug a large well around and below them, filled the well with 2B crushed stone for maximum drainage, re-set the boxes, and then re-did all the connections with wet-location splices. All wires got traced and labeled, while I was at it. Hopefully that lasts more than 20 years, but we will see.
/ Making electrical wire longer #15
Those green boxes are actually rated for electrical also…not sure about one in photo, but i have used them in past my electrical house sells them. Lid says electrical imprinted on it. They also sell traffic rated concrete ones.
/ Making electrical wire longer #16
I would never put a splice underground. Unless it fiber optics. I have been in telco for nearly 40 years and have never seen a splice be waterproof. If it's below ground, it will get water in it.
/ Making electrical wire longer #19
Well, ive done underground splices for over 30 years….never had a call back. Even the utility companies here do them, no issues.
Could the difference be in climate? Alabama versus North Idaho?
/ Making electrical wire longer #20
If you really only need 2-3’ feet longer, that should locate your extension connection short end, either in your supply panel, or your downstream panel or box.
Normally you would have a couple feet of excess on both ends for making nice sweeping turns into your terminations. If you make your wire turn radius to the minimum allowed, into the smaller of the two panels, this should easily place the other end of the cable within the larger panel box, where you can do your extension connection within your panel.
If not, because you’re actually more than 2-3’ short, then you can add a sub panel next to your main, for a lot less than $1k.
I don’t understand this talk of underground splicing, it’s not like the length issue is going to end up , midway,underground.
2022 EZ-GO ELITE...
2019 Komatsu WA380-8 Loader (A64194)
2019 Komatsu...
2022 EZ-GO ELITE...
2011 TRAIL KING INDUSTRIES PNEUMATIC TRAILER (A60736)
2011 TRAIL KING...
2013 VOLVO VNL 6X4 T/A DAY CAB TRUCK TRACTOR (A59912)
2013 VOLVO VNL 6X4...
Miscellaneous Mini Excavator Attachments (A61572)
Miscellaneous Mini...
