Makeshift welding table
/ Makeshift welding table #31
Not much to worry about on older diesel crawler loaders, especially with rubber mounts on the engine. There's only a simple electrical system.
I was thinking more generally about welding on vehicles. Would it be safe to use the same principle on a modern car with computers etc.
/ Makeshift welding table #33
It's done everyday. I am not saying it is recommended. But when a battery is disconnected it usually will suffice, as long as the work clamp is kept close. Welding with High Frequency with a TIG welder is another story though.
Thanks for the clarification
/ Makeshift welding table #35
I have used buckets and beds and other things. I have used a grill befor it works great with an old stripped out grill. Back when I was 21 I got broken up in a car wreck. I was out of commission 10 weeks. I had the Miller thunder bolt out in the shop and I had a 110V wire welder and the torch. I couldnt get out to the shop with a broken leg so I got dad to go out to the junk yard and get me an old gas grill that had cast grates. We had an old dryer outlet on the porch and I set up shop on the back porch.
The grill made a nice slag catch and also kept the porch paint from damage. THe grill stand made a nice carrier for the 110 welder and tank. I had a plte that fit over the grate to make a welding table.
I ve never had any damage done to a machine from welding on it but I did kill . an old wester auto battery charger one time. I hade it attached to a backhoe I was putting a thumb on and charging the battery on the hoe. I had moved my ground and I think that caused it.
I have a burning table kit here some where that was made for a 55 gallon drum. You delid it and set this in. It was an angle iron ring that the bottom leg dropped inside the barrel. I was getting some that didnt fit that snug that came from a ventilation duct company. Tey worked good just make the slats for them. some how I think i let them get away.
2008 Jeep Wrangler Unlimited 4X4 SUV (A59231)
2008 Jeep Wrangler...
GENERAC MAGNUM PORTABLE LIGHT TOWER (A59823)
GENERAC MAGNUM...
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
2017 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2017 Peterbilt 567...
2025 MMS MS36C (A60463)
2025 MMS MS36C...
Zero Turn Mower (A59231)
Zero Turn Mower...
