Main bolt replacement
/ Main bolt replacement #21
Oh shucks, any good proper diameter graded bolt could be used.
Baring that DOM shafting (proper size) with washers and cotter pins on both ends could also serve.
Those pins operate in sheer and not tension hence I suggest graded material.
The shoulder bolt design they used is simply a more sophisticated design of the simple pin.
The main advantage of using a shoulder bolt and lock nut is that this configuration cannot accidently come loose while a cotter pin can be snagged.
Just to close this out, got the part in 48 hours. Dealer special ordered from Branson. With shipping it was less than $25.
Thanks for all the help and finding the right part number.
2004 PROCO 130BBL VACUUM TRAILER (A60736)
2004 PROCO 130BBL...
2025 AGT STSD10 72" Grain Drill (A60463)
2025 AGT STSD10...
2020 LCMG AS1932E ELECTRIC SCISSOR LIFT (A59823)
2020 LCMG AS1932E...
Hydraulic rail grinder (A61307)
Hydraulic rail...
AMERICAN 14 T/A DOG HOUSE (A60736)
AMERICAN 14 T/A...
2020 Kubota RTVX1140 (A60463)
2020 Kubota...
