Main bolt replacement
/ Main bolt replacement #21
Oh shucks, any good proper diameter graded bolt could be used.
Baring that DOM shafting (proper size) with washers and cotter pins on both ends could also serve.
Those pins operate in sheer and not tension hence I suggest graded material.
The shoulder bolt design they used is simply a more sophisticated design of the simple pin.
The main advantage of using a shoulder bolt and lock nut is that this configuration cannot accidently come loose while a cotter pin can be snagged.
Just to close this out, got the part in 48 hours. Dealer special ordered from Branson. With shipping it was less than $25.
Thanks for all the help and finding the right part number.
UNUSED SDLANCH SDLFP30 EELCTRIC PALLET JACK (A62131)
UNUSED SDLANCH...
CATERPILLAR 259D3 SKID STEER (A62129)
CATERPILLAR 259D3...
Four (4) Michelin 520/70R38 Mega Bib Floater Tires (A63116)
Four (4) Michelin...
2002 John Deere 4510 Tractor (A64047)
2002 John Deere...
New/Unused 7ft Fork Extension (A61166)
New/Unused 7ft...
17395SFL (A61568)
17395SFL (A61568)
