Conical PTO Bolt Replacement???
/ Conical PTO Bolt Replacement???
Well, I gave it a few whacks with a hammer today then tightened the nut. After working for a bit longer, I got some more but since then it’s been pretty much solid. I guess the bolt has just been finding its home. Thanks for all the input guys!
/ Conical PTO Bolt Replacement??? #22
Matlax,
It's a sign the soft nut is yielding. Replace it with the factory nut or grade 8 and torque to spec.
Matlax,
Thanks dado. I have one coming from the manufacturer so I’ll be getting it swapped out.
/ Conical PTO Bolt Replacement??? #24
Matlax,
It may have been. But with him using the technique of tapping on it and tightening he probably has the joint socked up tight. Still, drawing it in with proper tension would yield a slightly different, elastically stretched, loaded zone. Proper tension, torque, is not speced though. Who knows how far its needed to go. 🤔
2014 CATERPILLAR 924K WHEEL LOADER (A65053)
2014 CATERPILLAR...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
2002 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2002 Ford F-250...
2024 BOBCAT T76 SKID STEER (A67148)
2024 BOBCAT T76...
New - Front mount rototiller
New - Front mount...
2018 Holbart 210 MVP Mig Welder (A64194)
2018 Holbart 210...
