Main bolt replacement
/ Main bolt replacement #21
Oh shucks, any good proper diameter graded bolt could be used.
Baring that DOM shafting (proper size) with washers and cotter pins on both ends could also serve.
Those pins operate in sheer and not tension hence I suggest graded material.
The shoulder bolt design they used is simply a more sophisticated design of the simple pin.
The main advantage of using a shoulder bolt and lock nut is that this configuration cannot accidently come loose while a cotter pin can be snagged.
Just to close this out, got the part in 48 hours. Dealer special ordered from Branson. With shipping it was less than $25.
Thanks for all the help and finding the right part number.
KUBOTA LOADER BRACKET (A62130)
KUBOTA LOADER...
330 GALLON POLY TOTE W/ CAGE (A62131)
330 GALLON POLY...
Vermeer 5400 Rebel Hay Baler (A61166)
Vermeer 5400 Rebel...
2017 Bobcat T770 Compact Track Loader (A63118)
2017 Bobcat T770...
Kubota RTV 500R-A (A64047)
Kubota RTV 500R-A...
2007 E-One Pumper Fire Truck (A61568)
2007 E-One Pumper...
