Mahindra Question and 3 pt Backhoe Hydraulic Problem
   / Mahindra Question and 3 pt Backhoe Hydraulic Problem #11
N would not be power. It is the return for you Power Beyond to run your 3pt hitch and remotes if you have them. When you get a picture of your valves and block I will put in a PDF with lines showing proper connection.
   / Mahindra Question and 3 pt Backhoe Hydraulic Problem #12
On your "N" port is that a dual ported connection?
In that it has 2 possible connections, one on the side and one on the rear?
The way your drawing is it would seem to be a single port.
Power beyond connections can be a royal pain,
some power beyond connections will require a plug to be installed to divert flow out thru them while they are internally ported to the tank.
If you have two lines connected to the "N" port that would behave similar to having 2 lines connected to the pressure port.
"I need to go an see if I can identify the 3 hoses (originally) coming from the loader connected to the ports."
If your loader valve had 3 lines going to the block the "P" port should have been pressure to the loader,
the "N" port the power beyond port from the loader, and the "T" port the tank return from the loader.
If this was the case your installation becomes a bit more challenging.
Let's see if I can guess whats going on.
3 possibilities and different configurations.
Original
"P" goes to loader pressure port,
"T" from loader return to tank,
"N" from loader Power Beyond (likely to3pt)
NEW with Back Hoe
"P" goes to loader pressure port, (no change)
"T" from loader return to tank, (no change)
"N" not connected, piped to rear of tractor with a Quick Connect
Back Hoe pressure in from Loader Power Beyond (original "N" connection) now connected to quick connect for back hoe supply pressure.
Also a new line added to "T" with Quick Connect at rear of tractor for Back Hoe.
Back hoe is connected to 2 Quick Connects;
(1) Supply (pressure) from loader power beyond originally connected to "N"
(2) Return for Back Hoe connected to line and quick connect added to "T"
3 point does not work with back hoe connected
New with Back Hoe removed;
Install a jumper from Loader Power Beyond Quick Connect (used for Back Hoe Pressure in)
to
The Quick connect that was added to the "N" port.
The 3 point will now work.
This jumper must be installed when ever the back hoe is not hydraulically connected to the tractor or the hydraulics will be dead headed and over loaded.
I hope that this is not too confusing.
Good Luck
Lou
   / Mahindra Question and 3 pt Backhoe Hydraulic Problem #13
Lou is 100% correct! Thanks Lou, I have a hard time explaining it so that it is understood! :laughing:
   / Mahindra Question and 3 pt Backhoe Hydraulic Problem #14
It is hard to explain something in writing at times,
pictures and lines can work better at times.
I was thinking about trying to draw up the different possibilities,
but decided to just try and write it out.
It's much easier to just be hands on with things.
Ok, guys, here are some pics.
I cannot take a pic of the TNP manifold because it is blocked by framing.
That, also makes it a pain to connect suff.
The diagram I sent previously showing the TNP positions is what the picture would look like.
hope is is clear to see with the following. IMG_20201005_102729_3.jpgIMG_20201005_102722_8.jpgIMG_20201005_102716_5.jpg
Having a problem sending pictures to post ......... did it all up, posted quick reply, and it disappeared !!!
   / Mahindra Question and 3 pt Backhoe Hydraulic Problem #18
   / Mahindra Question and 3 pt Backhoe Hydraulic Problem #19
Nice diagram.
   / Mahindra Question and 3 pt Backhoe Hydraulic Problem #20
Nice diagram.
Thanks! Not as clear as your directions but hopefully between both the OP can figure this one out.
John Deere 3025E (A53317)
John Deere 3025E...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
1980 Gleaner F2 with heads (A56438)
1980 Gleaner F2...
2000 FORD F550 SUPER DUTY SERVICE TRUCK (A60430)
2000 FORD F550...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
Club Car 4x4 Diesel Utility Cart (A59228)
Club Car 4x4...
