swa
- Joined
- Jul 6, 2012
- Messages
- 13
- Location
- Cotswolds, UK
- Tractor
- Kubota L4630, Iseki TX 2160, Ford 4000 (ex), MF 164 (ex), Grey 1951 fergie (ex),
Update: feed to and from the hedgecutter is on Spool 2 using both ports. The lever is held open by a bungee as suggested by several including the Kubota dealer. The lever can be in either direction as the machine is ambivalent to that.
It was important to change the motor overflow to a low pressure area - the hydraulic tank. This had been previously connevted wrongly.
Flow required is 12-20 Lpm so set at about 1500 RPM and seems to work well with no heat build up.
Thanks for all the input.
