T port valve connection
   / T port valve connection
Can I use only one filter on the suction?
   / T port valve connection #12
You can run filters in parallel but they usually on higher flow systems NOTE: Their are specific filters designed for suction use and not all filters will work in suction application.
For a simple gear pump you can use a suction strainer that is made from wire mesh.
   / T port valve connection #13
On my homemade backhoe, I only run a suction strainer for the pumps and a filter on the return of both pumps.
Whatever dirt or trash that may enter the system during connecting/disconnects quick connects, stay trapped in the filter and doesn't even reach the tank.
The tank has very little risk of contamination in my opinion, as long as precautions have been taken when filling said tank.
Brandt Grain Vac - Mod. 5000EX (A59814)
Brandt Grain Vac -...
Towable Chemical Applicator Sprayer (A59228)
Towable Chemical...
2010 Ford F-550 4x4 Venturo HT40KX 3 Ton Crane Mechanics Truck (A59230)
2010 Ford F-550...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
