Mahindra loaders?
/ Mahindra loaders? #21
Slippy said:
I have been informed that Mahindra bought out KMW.
rback33 said:
Wow... completely not true....lol
Slippy said:
How do you know?
Well I will have to back up rback33's statement.
I happen to communicate with a fairly nefarious low-life type ;) who, despite his character flaws, is well connected to the inside working of KMW. My source says that it is untrue.
/ Mahindra loaders? #22
DavesTractor said:
Miami,
This problem is not brand specific, it's more of an operator thing.
Thanks Dave.
I'd agree it seems like an operator thing except for a couple of reasons:
One is since it happened the first time and the local rep mentioned the "over-extension" (why wouldn't they put stops on it to prevent that??) possibility I have been very careful not to do that.
And second how come nobody else has done this and the rep says he has never heard it done? Am I the only person who would "over -extend" cylinders?
That's the thought process anyway. I guess I am a bit bothered by the fact these are not standard cylinders and have to be bought from Mahindra at an exhorbinant cost!
Miami
/ Mahindra loaders? #23
While everyone does it, backdragging is not recommended is generally is considered abuse. The 'over-extention' comment is very likely related specifically to the action of backdragging, but having the bucket in that same position while lifted into the air is required to empty the bucket. So while the bucket position my be the same, the backdragging creates a substantial amount of stress on the loader and that that is why you are bending the cylinders.
Many people have bend their cyliders while backdragging but the term 'over-extended' may not have been used. The effect is the same. If you backdrag you better be careful.
/ Mahindra loaders? #24
[ Many people have bend their cyliders while backdragging but the term 'over-extended' may not have been used. The effect is the same. If you backdrag you better be careful.[/QUOTE]
Thanks for the reply. I still think others would have done the same thing. I even asked the rep about back dragging the first time it happened and both he and Mahindra told me it 'should be no problem'.
Again thanks for the comments.
Miami
/ Mahindra loaders? #25
If you are careful when you do it, it should be 'no problem.' But there is a technique to it and as Dave wrote earlier, this is an operator issue, not an equipment issue. I would guess that you are attempting to hold the weight of your tractor with the cylinders at full extention while backdragging aggressively. If so, then what you are doing probably would qualify as abuse and that is probably why your cylinders are bending.
/ Mahindra loaders?
I've done alot of backdragging with my Mahindra/Great Bend and a friend's Kioti 3054 and have not had a problem. I have trouble remembering that I can't use my tractor for a bulldozer. I understand being upset about those cylinders. Wish there was some way for us to all see what angle everything is at when you're doing this, maybe we could help. On the other hand it may be a design flaw in your particular loader. Have you compared it to any others? I'm no expert just grasping for possibilities.
/ Mahindra loaders? #27
Well it could be that you have some sort of odd problem wih your loader, but I doubt it. Remember that when you lift or curl you can't apply more psi to the cylinders than the pressure relief will allow. But when the spool valve is closed and your cylinders are extended and you are going backwards (or forwards for that matter), you can apply more pressure than the system is designed to handle. When the spool valve is closed, it cannot protect the cylinder from too high a load as the pressure relief is on the other side of the spool. Plus an extended cylinder is much more prone to bend then one that is retracted. I probably did not explain that very well....so somebody feel free to help me.:eek:
/ Mahindra loaders? #28
Dave, I understood your explanation quite well. What I don't understand is why anyone would buy such an expensive piece of equipment, and be too cheap with their time in reading the instruction manual. My KMW loader manual specifically warns not to back drag at greater than 15 degrees. Damage is not warrantable, as it is considered abuse.
I also don't understand how people get the idea they are supposed to back drag with front wheels off the ground, and the loader tilted in dump position. Ignorance, or apathy, or both, I guess.
Bob
/ Mahindra loaders? #29
Bob
My manual indicates the bucket should be "level on the ground" when backdragging, i.e., what the manual refers to as backfilling and backgrading. A lot of times if what I am backdragging is pretty loose I will also use the float position, as this takes a lot of pressure off the loader's cylinders.
/ Mahindra loaders?
I bought my tractor to use and use it I have! If there was a design flaw in all of these or they could be easily damaged I would know it. I am ashamed of some of the things I have subjected my poor tractor to. I have no problems backdragging or bulldozing for that matter. If I only had 6 way tilt!
/ Mahindra loaders? #31
I certainly don't think I could have explained it any better myself... 15 Degrees is the maximum recomended by most.
/ Mahindra loaders? #32
miami said:
I have a 4500 with a great bend loader and have bent and or broken 4 of the upper bucket tilt cylinders. Mahindra says it is impossible to do. I say it isn't!
Last week when it happened I was backdragging a shallow creek, pulling the mud and weeds out during a dry spell, when I heard a big crack and one of the cylinders arms had bent and cracked in half.
Has this happened to anyone else??
Miami
High Country Stables
Dallas Ga
i have a 4500 2wd and i guess i have a different loader because i only have 2 tilt cylinders one on each side, i back drag clay with my bucket at a 90 degree angle and have never had a problem. maybe i should be more carefull, i do it with the front end off the ground. but so far no problem, not even a leak.
/ Mahindra loaders? #33
DavesTractor said:
Miami,
First of all, welcome to TBN. On your loader issue, absent a faulty cylinder (which is rare), this is normally caused by having the bucket cylinders too far extended while back dragging. I bent my first one about 20 years ago on my dad's 60HP IH. I had the bucket at a severe angle and I was backdragging like mad. It sure worked great until I bent a ram. That cost me about $250, and that was a LOT of money back then. I'm more careful now. This problem is not brand specific, it's more of an operator thing.
i think im going to be more carefull with my loader in the future, but it seems like it can handle whatever i through at it, of course this same loader goes on much bigger and more powerfull tractors.
/ Mahindra loaders? #34
I wonder what Fish Whisperer did to get banned.... I have gone back and looked at most of his recent posts and there was nothing disparaging in there.... I suppose they may have been deleted though....
/ Mahindra loaders? #35
rback33,
I wonder too. I have never seen that before. He always seemed polite to me.
/ Mahindra loaders? #36
Tim_in_IA said:
rback33,
My guess is we will never know... My thought were the same as yours.. always seemed polite to me... but on the other hand, even I have had a post pulled by the mods before :D.. I kinda snapped one day. Maybe he had a bad day and went overboard.. it happens to us all sometimes...
/ Mahindra loaders? #37
Says on this page that Quicke aquired KMW in 1988. Is this still true???
History
/ Mahindra loaders? #38
It was until 1997 when the current management bought the assets from ALO. Keep reading further down the page.... LOL And if you find the picture of me....I am NOT left handed.. the pic is reversed.
/ Mahindra loaders? #39
he saw some kubota dealers posting bad stuff about mahindra on this site and said something about it, and the moderator was a kubota guy..........................anyway.
/ Mahindra loaders? #40
he saw a dealer from another manufacturer downing mahindra on this site and questioned him about it, the moderator was a big fan of this manufacturer and ...you know how that goes..
2022 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2022 KENWORTH T680...
1980 19ft Sailboat w/ 2018 Continental Trailer S/A Boat Trailer (A64557)
1980 19ft Sailboat...
1996 Polar DOT 407 Single Comp Insulated Diesel Trailer (A64194)
1996 Polar DOT 407...
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
2024 Polaris Sportsman 570 AWD ATV (A64557)
2024 Polaris...
