M9540 loader question
/ M9540 loader question #12
Great!
Fixed at almost zero cost!
I really appreciate all the advice
Thank you
It's got hydraulic lines running from one of the rear remotes to the front for a third function I now have to figure out how to disconnect the hoses they aren't like quick disconnects I am used to with skid steers and other tractors so there must be a trick
So far I have replaced one fuel line that was leaking off the fuel pump with a 3/16s hose and I have moved the tires in they were set at the widest setting a little over 8ft wide and they didn't line up with the front tires and I need them to so I can spray after I plant so I moved them in to 81.5 inches that was fun removing each one and changing the hub placement but I'm really liking the tractor Can't wait to pull the planter at more than 2mph that's what I was topping out at with my 55hp
/ M9540 loader question #14
One suggestion I will make to you about the Kubota loader valve:
Take a look where the cables join the valves. You'll see the tiny pins and tiny clips that hold them in place. Do yourself a favor and order a few of them and keep them in the tractor. The little clips get knocked off easily and the pins fall out then no loader.
For $5 bucks you'll have them there and ready to install should they fall off.
Thank you for the suggestion I will do that
2019 BOBCAT E45 EXCAVATOR (A59823)
2019 BOBCAT E45...
John Deere 6110M (A60462)
John Deere 6110M...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2019 BOBCAT MT55 WALK BEHIND SKID STEER (A59823)
2019 BOBCAT MT55...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
