M9000 low speed
/ M9000 low speed #1
BAGTIC
Thayer, MO
What is the slowest speed in a Kubota M9000. I am still looking for the right tractor and the M9000 looks attractive but one thing it must do is travel very slowly as I want to use a chain trencher on it. The trencher manufacturer recommendations are:
"You would need at least 17gpm to operate the trenchers - If you are interested in a larger trencher - i.e. a 4'6" machine digging 14" wide you would want a high flow for best results.
you could definitely put the trencher on a tractor with quick attach plates
about 5 ft per minute is an optimal speed for trenching.
Carbide tipped rock teeth are available if you need them."
I have decided drawbar hp is not that important to me. It will be used primarily as a tool carrier and hydraulic output for trenchers, tree shears, brush hogs, rock pickers, rotor tillers, and other attachments is more important than traction and pulling abilitity. I would also like a loader that will lift 3,000 pounds.
The M9000 specifications show exceptionally high hydraulic performance. Are there any other brands/models in that size/price range with comparable hydraulic performance.
/ M9000 low speed #2
To be able to go that slow the tractor would have to be equipped with a creeper. With the standard transmission 1.4 mph is as slow as it can go,with the creeper it will add 6 speeds between .22 and .71 mph.
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2022 CATERPILLAR 259D3 SKID STEER (A65053)
2022 CATERPILLAR...
2011 CLARK OIL FIELD FLOAT (A65643)
2011 CLARK OIL...
2012 Ford F-150 Pickup Truck (A64194)
2012 Ford F-150...
Femac T9 70 REV Excavator Mulcher (A66285)
Femac T9 70 REV...
