Sid Post
Platinum Member
- Joined
- May 28, 2010
- Messages
- 781
- Location
- TX and OK
- Tractor
- Massey 5711D, Kubota L4600, Kubota B2601
A few non-specific thoughts:
I like the MF 4707 for not needing DEF and a really good build with a heavy frame and axles. It also has some really nice features like a 3-point function on the fender and declutching on the shift lever among a couple that seems very user friendly. What I am less enthusiastic about is the view blockage by the loader arms, specifically the rear posts which are pretty tall restricting views of the obstacles and terrain in front of the tractor.
The Kubota M5 (probably 91Hp) seems to be competitive. I don't know anyone that owns one or anything larger than the 7060 actually. I own a B2601 and L4600 myself so I am familiar with the brand and find the L4600 to be generally over-rated though it is a great tractor (I should clarify, my L4600 is light in the rear even with Rimguard and weights, the front end is a bit light for the loader capacity, the center of gravity is a bit high and, it is a bit narrow for work on sloped). This makes me a little skittish about Kubota's large tractors. The engines, drivetrains, and hydraulics are very good so, I am somewhat attracted to them over other brands.
For anyone that has operated or been around these two options, how would you compare and contrast them? For use around trees, corrals, buildings, etc., does one have a real advantage over the other?
TIA,
Sid
- John Deere and Kubota dealer support are much better than other options
- I have sandy and wet loose land to work traction in that ground is important
- 70Hp is a low as I want to go but, PTO Hp doesn't need to be huge either for mowers and balers (nothing over a 12' bat-wing ever envisioned with a 7' medium duty rotary being 99% of mower use)
- Loader capacity is important to me, meaning sheer lift weight occasionally and smooth operation for normal mundane tasking
- Good ground engagement in firm soil is required for tillage
TIA,
Sid
