M7060HDC Tool Box
/ M7060HDC Tool Box #1
CMelder
Bellville, Texas
2015 Kubota M7060HDC
Howdy Ya'll,
Just wanted to share with you my alternative to the tool box mounted under the FEL. I went and purchased a Tool Bag and set in the front right corner inside the cab. If I need it, open the door n grab it. Also seems to make sense to bring the tools with me rather than making several trips to the tool box.
Husky Tool Bag - 12 inch - #257 759 at your favorite Home Depot.
/ M7060HDC Tool Box #2
Great addition.
I don't carry a lot of tools. But I carry specific tools. The bag isn't as important as what's in it. :)
Welcome to TBN and congrats on the new tractor.
/ M7060HDC Tool Box #3
A guy, excellent at fabrication, has made this type of toolbox which utilizes the right hand step mount to support the box.
If you have a loader the right door is all but useless as a door.
Dave M7040
/ M7060HDC Tool Box
Not bragging about the bag, $10, not too impressive, just thought I would share a quick solution that may help someone. Obviously, Kubota could/should have done a much better job with the toolbox location. I just sold my 2000 New Holland TN70 and the toolbox was still intact and holding my essentials. A few tools, and an assortment of hitch pins, bushings, R clips, etc. I know how handy those extra items can be.
/ M7060HDC Tool Box #5
Thank you for posting. What a great tractor that series is.
/ M7060HDC Tool Box #6
I go into woods occasionally after downed trees over rough terrain I think I would eventually tear it off .thanksRick
/ M7060HDC Tool Box #7
The cold weather cracked my original factor tool box so I made a replacement using plate steel. I constructed it with the same original dimensions but used a "double hinge" concept so that it could open completely.
attachment.php
attachment.php
/ M7060HDC Tool Box #8
I used to see more 50 Cal. Ammo Boxes as for Tool Boxes... anyone use them anymore ?
I purchased two, on sale at TSC, steel construction, $9.00/ea. a while back, hoping to attach them on the fender portion above the rear tires, tied in at the bottom of the ROPS.
Might make a steel plates or maybe aluminum, for reenforcing the bottoms which will also assist in mounting.
Another thing on the To-Do List.
/ M7060HDC Tool Box #9
MBU, very nice work. You are a Craftsman.
/ M7060HDC Tool Box #10
I've got a couple I need to install on either the tractor or zero turn. I now use a bag similar to yours in addition to the factory one on my T4.75. I keep the bag in the cab along with some cold water and snacks. A long day of brush hogging and you need to take a break every once in a while.
/ M7060HDC Tool Box #11
mbu--That is a good looking job and the box is in the right place.
New/Unused Wolverine 72in Quick Attach Brush Cutter (A61166)
New/Unused...
2013 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61568)
2013 Freightliner...
2022 Forest River R.pod Towable RV Trailer, VIN # 4X4TRPV28NR208064 (A61166)
2022 Forest River...
KUBOTA BUSH-HOG GEAR BOX (A62130)
KUBOTA BUSH-HOG...
(2) UNUSED 420/85R30 TIRES W/8 LUG RIMS (A62130)
(2) UNUSED...
Pallet of Fork and Frame Mini Skid Steer Attachment (A61567)
Pallet of Fork and...
