M7060 with bad brakes!
   / M7060 with bad brakes! #1
romoni
Paquetville New Brunswick Can.
Branson 8050 2015
Hello everyone, I don't have the Branson anymore, I got myself a Kubota M7060 12 shifts, 2016 with an M21 loader and snow blower, 1340 hours on it, really nice tractor but. The one and only problem with it, and it is quite a serious one is faulty travel brakes. I have to pump the pedals to get brakes, the right one will go right to the floor on the first pump, gains three inches on the second pump and is good after the fourth pump. The left brake pedal will not go all the way to the floor on the first pump but stops three inches from the floor and is good after the second pump. Once foot ¨primed¨, both brake pedals stay within half to three quarters inch from their resting position with no sponginess OR sinking with applied foot pressure, at that point both brakes will positively lock the back wheels. As soon as you release the pedals they are both instantly ¨deprimed¨ again. The oils and filters were just changed and trans oil was replenished with Kubota UDT. I have been over forums and there is not much on this as there seems to be very few cases. Since both brakes will sit pretty after being pumped, could the master brake cylinder be the problem? Any help would really be appreciated and merry Christmas to all!
   / M7060 with bad brakes! #2
It’s possible. Hard to tell without driving it and more info. My bigger kubotas have a lot of sensitivity on the brakes if the master cylinder reservoir is even a little low.
I replaced a master cylinder on my 126x this summer. It had a bad leak. But mine is a 2011 with 3,000 hours.
They should work with a lot less hassle than you’re describing. That’s not a lot of hours to be having those problems.
   / M7060 with bad brakes! #3
romoni
Have you attempted to bleed both RH & LH brakes? It appears from viewing M7060 parts catalog that brake master cylinder is supplied hyd oil from power steering control valve. Bleeder valves are on each side of trans case.
From what I found out the master cylinder has a constant supply of transmission oil.
romoni
It will be my next move tomorrow. Thanks!
   / M7060 with bad brakes! #13
Ok that’s better than mine. Mine has a flimsy rubber cap and you fill it like an automobile master cylinder
   / M7060 with bad brakes! #15
Transmission oil? I can't think that the brakes use transmission oil or any other oil. Surely they use brake fluid. Anyone else know for sure ? Manual should say.
   / M7060 with bad brakes! #16
Yes, the power steering circuit feeds the brakes on that tractor as well.
   / M7060 with bad brakes! #17
My Kubotas brake master cylinder uses Kubota Super UDT
   / M7060 with bad brakes! #18
Wow ! I am amazed that tractors (at least some Kubotas) use oil instead of brake fluid for brakes. Wonder why AND I wonder what differences that makes in brake behavior?
   / M7060 with bad brakes! #19
Most tractors with hydraulic brakes use transmission/hydraulic fluid to operate them,
usually they are also at least partially immersed in it.
   / M7060 with bad brakes! #20
Thanks. I did not know that. I see wet brakes and wet clutches bantered about all the time and never had a good overview of what got wet with what. I'm sure my MF2660 brakes imbedded within the large rear axle housings are the tranny fluid flavor of wet.
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
UNUSED RAYTREE RMRB72-72" HYD POWER RAKE BUCKET (A60432)
UNUSED RAYTREE...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
SKID STEER QUICK ATTACH PALLET FORKS W/ 48" FORKS (A60432)
SKID STEER QUICK...
JOHN DEERE CP24 ASPHALT PLANER (A60429)
JOHN DEERE CP24...
2021 Kubota SVL75-2 Track Loader (A61306)
2021 Kubota...
