Comparison M59 vs L45 Pic
/ M59 vs L45 Pic #1
CHDinCT
Conn. & Florida
Kubota BX25, Z422-KW
No, I'm not shopping for one of these commercial TLB's, though I'd sure love to own one of them. I was tire kicking at one of my local Kubota dealers that sells more construction machines than homeowner/ag stuff and he had these two machines back to back in the front of the lot, so I snapped this pic. Besides being nice tractor ****, it might be useful for someone comparing the two size wise. I never thought the L45 was small, but it sure looks it in this pic being next to the M59. Oh, yeah, both machines were plumbed for the FEL third function and the hydraulic BH thumb. :licking: :licking: Don't let your wife catch you staring at this stuff or she'll think you're a pervert like me. :laughing: :laughing:
/ M59 vs L45 Pic #2
Great picture. I've never seen them together like that before.
/ M59 vs L45 Pic #3
That's a huge difference in size. The L looks like a garden tractor with implements.
/ M59 vs L45 Pic #4
I'm lucky enough to have the M59 - bought mine used for a very good price and fixed it up. Couldn't live without it now, doing what I do. Anyway, the size is very deceptive. Sitting by itself in the open it looks like another little red tractor from 20' or more away. But when placed next to something that provides some perspective (e.g., up on a trailer) it looks much larger.
/ M59 vs L45 Pic #5
Kinda like wife wanted must have own tractor please send pictures of tractor
/ M59 vs L45 Pic #6
I never realized there was that much difference in size,especially in the backhoes.Nice picture.
/ M59 vs L45 Pic #7
What a great photo. I had no idea the difference was so great. Good comparison.
/ M59 vs L45 Pic #8
Nice picture, I also didn't realize there was such a big size difference.
/ M59 vs L45 Pic #11
That's also the first photo I have seen of one of the commercial TLB's with turf tires on it too.
/ M59 vs L45 Pic #12
Couldn't help but look at this one a few times. Not only is it rare to see, but I'm sure that many of us would like to see quite a few tractors sitting side by side, as well as some specs that aren't available. Anyone have one of the John Deere 3 series sitting next to a Kubota large frame standard L's? Seems like the Kubota specs out well in size and capabilities, but much cheaper (new or used), seemingly with a lower center of gravity (important spec that isn't published) and better clearance. (Yes, I know that the Deere has more bells and whistles, and that the Kubota is wide enough to need 6' implements, but many Deere users add wheel spacers and then also need 6' ). Seems that something like a used L4600 would be the perfect do it all tractor. Light enough to use in the yard but powerful enough to run a 6' brush cutter. L4600hst - 3197lb 36.8pto / 3720hst - 2900lb 35pto
/ M59 vs L45 Pic #14
Nice picture, The m59 has a big price tag too.
/ M59 vs L45 Pic #15
Full size backhoes are called 'full size' for a reason. Being an old fart I remember when the JD300 was considered big enough for almost any 'farm' job and the Case 580B for most 'construction' work. Seems that the l45/47 and M59/M62 would hold their own in both cases (and they also have that 3 point hitch option).
/ M59 vs L45 Pic #16
Old thread, but nice pic.
I have done a few side x side shots with the equipment I have owned. L3400, Mx5100, Ford 4500tlb and Ford 5500tlb.
A single picture of a piece of equipment doesn't put things in perspective unless there is something familiar in the picture to scale it with.
Look at a single pic of a D11 dozer. Looks more or less the same as a D3.
But put both side by side in the pic and WOW
/ M59 vs L45 Pic #17
Weight M to the L's is within 1,500 Lbs. The L TLB's all have too small tires, and some weight, making them not very good in soft ground. The M front tires on and rear 43" tires would make a difference. The M could stand some larger front tires also.
/ M59 vs L45 Pic #18
Hard to believe only a 1500# difference in the two machines.
Strictly from looks alone, it looks like a 9000-10000# how sitting beside a 5000# hoe
/ M59 vs L45 Pic #19
Just going by the published specs. I think the L47 should have another 800 lbs of steel added to get it to 8000 Lbs, and the M62 another 1200 Lbs added tor so so it weighs a good 5 ton.
/ M59 vs L45 Pic #20
Many thanks to CHDinCT for posting that original 2014 photo of the M59 vs the L45. Since then there has been some discussion of how the M59 looks next to a full size backhoe, so here is ours in the same sort of shot for comparing them. I'll repost CHDinCT's original photo again just so we have them all in the same place, too.
I'm showing the Kubota M59 vs a JD310SG typical full size backhoe used the world over. Since the JD310 has a cab, 50% more HP, and roughly twice the total weight & twice the lifting capacity of the M59, I was surprised at how close they look to being the same size - although any metal part you want to compare is much beefier on the JD310. The JD also has power seat, ride control, AC, heat, radio...and the list goes on and on...
Still, the Kubota is the more accurate machine and we use it much more often.
Enjoy,
rScotty
2020 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2020 Kubota...
CAT D8 (A58214)
CAT D8 (A58214)
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
2023 Kubota RTVX1140 4x4 Diesel Utility Cart (A59228)
2023 Kubota...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
