M5040 purchase thoughts
/ M5040 purchase thoughts #11
jrl@nf.sympatico.ca said:
I don't believe those are bad quotes for that tractor. I finally have a firm quote on a new 4WD M7040 with cab, AC/DC(I mean heat), two remotes, FEL, full tank of gas for around $44,000.00 with 0% financing for four years. I also got a quote from New Holland for a T4000 series tractor in the same HP range. The guy hardly wanted to even quote me. I also looked and got a quote for a JD which was quite a bit higher than Kubota.
Mainly I will use the tractor for harvesting about 40 acres of hay but also for moving piles of manure and pulling wind downed trees either up or down the hills so I can cut them up.
Geez, jrl, $44K for an M7040 cab!? I guess $28K for an M5040 wouldn't look bad. A few months prior I asked for a quote on a cab M7040 4WD w/hydraulic reverser that was on the lot. Wanted to compare with the price of a used M7040 I'd found on the web. The same place quoted $35K for the new M7040.
It was more than I needed/wanted to spend so passed it up. If I'd known they were $44K tractors, I'd have jumped on the new one. Prices must be different where you are.
Dove Hunter: I ended up opting for an MX5000 4WD with FEL that had been on the lot awhile. It's been replaced by the MX5100 and they wanted to move it. Paid $22.2K for tractor w/852 loader, 2 rear remotes, filled rears, bucket hooks, and a block heater. When I looked hard at my needs, I really didn't need any more tractor.
Bob
If I could get a quote like Conn, I wouldn't have to think about it! But until I get a little better quote, I'll continue to wait and build some more funds.
/ M5040 purchase thoughts #13
So in other words, if I'm chewing on this purchase, I need to go ahead and swallow it! I didn't make it to the dealer this morning, but will have some time at the end of the day. The payments are easy, the downpayment is what's killing me. I have to shell out a bit more than the JD I quoted on the down payment ($800), but I think I'm getting a heck of a lot more tractor for the money. It won't break me by any means, but it knocks quite a bit out of my farm fund. Fertilizer isn't going to be cheap this year.
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
2015 Audi A4 Sedan (A59231)
2015 Audi A4 Sedan...
2004 VOLVO VHD TRI AXLE CEMENT MIXER (A59906)
2004 VOLVO VHD TRI...
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
case 370 glass door never installed (A61307)
case 370 glass...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
