MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,697
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
Chris,
The 1/4" line has the threaded Male end for the Pioneer fitting, the other end is threaded Female fitting to connect to the Top Link fittings which are also Female.... hence the double Male fitting.
The difficult part will be connecting to the Factory Remote fittings..... they don't appear to be your typical quick-disconnect type... they don't have the sleeve to pull back.... kinda hard to describe....
I will probably just go ahead and take the top link and hoses to the dealer and ask them to assist in either providing me with the correct fittings, or tell me what I need to get to be able to attach to the factory rear remote fitting.
I'll try and get a pic or 2 tomm of the factory rear remote to give you an idea of what I'm talking about.
Stu
I think that you will find that a std 1/2" QD fitting will work. How to connect-disconnect. Just push the male fitting in to connect. To disconnect, push in and then pull out, all in one quick motion.
Hope that this helps you.
