M5040 Hyd Top Link ?
/ M5040 Hyd Top Link ? #1
PSDStu
Marianna, FL
Kubota, M7060 HDC12, L4060 HSTC, RTV 1140
I just ordered my Hyd Top Link and hose kit from CC&M and had a question about what if any additional fittings I will need to attach the top link hoses to my Kubota factory rear remote?
The hoses are coming with Pioneer Couplings if that helps.
Thanks!
Stu
/ M5040 Hyd Top Link ? #2
Well, my BX is a long ways from your M but when I made up my own HTL, I had to get these quick connects as the Kubota factory female QC on the tractor were not standard, nor pioneer I believe. Try doing a visual of these against your FEL QC's.
ISO 7241-1B Hydraulic Quick Disconnects
/ M5040 Hyd Top Link ? #3
I was just curious, but never having had a hyd top link, how do you plan to use it? What implements do you use that the top link will improve their function? I have a M-6800 and was wondering if this is something I would find useful. What did you pay for this? Sorry to answer your question with another question, so hopefully someone else will have the answer that you need. Thanks!
/ M5040 Hyd Top Link ? #4
I installed a HTL on my B 7510 for a few reasons..
1. ease of hooking up to different implements!!!!!!!!!! ( I can reach my control when hooking up, not sure if you can with a large tractor)
2. Allows more or less down pressure so to speak with my york rake and grader blade. Especially the rake when used with the gauge wheels.
3. when retracted, raises my implements further off the ground when loading on my trailer.
4. more flexability with my log splitter, fine tuning level. I hated having to kep turning the turnbuckle..
The biggest reason is so when using my 8' rotary cutter or 7.5' finish mower I can just use the factory rear remote to adjust the top link and not have to get in and out of the cab to adjust the top link.
Stu
/ M5040 Hyd Top Link ? #6
Sorry I don't know anything about your question, but I have a question for you. I just got an '08 M5040 with cab and am trying to find out if the freeze plug closest to the cab is threaded or not. There is a block heater in that hole on mine, but it's dripping anti-freeze. On the first white page in the manual (page 1 of Servicing of Tractor), there is the "Tractor identification plate" illustration. In that drawing they show the last freeze plug (right over the dipstick) with a hexagon in the center, where the others are just circles. This makes me think it might be threaded. I can't tell by looking at the tractor, since the block heater is already installed. Thanks in advance and good luck with your question.
Thanks for the info.
I just received my Hyd Top Link along with some 1/4 Hoses with one end Male the other Female, and the Pioneer coupling which of course does not fit my factory remote.
It looks like I will ned to get a double Male fitting to connect the hoses to the Top Link, and then try and figure out what I need to do to connect the hoses to the Factory Rear Remote Coupling........or replace the factory rear remote coupling?
Did you remove the Kubota factory installed Female coupling from your remote and then install the Quick disconnects in your link?
I guess I need to find out just what I need to do to get this hooked up and working.
I hope my dealer can assist in at least telling my what type/size fitting I will need to get this to work with my factory remote.
Stu
/ M5040 Hyd Top Link ? #8
Hydraulic top link is SUPERBLY handy.
  1. Adjust angle of attack for rear hay fork from the seat
  2. Adjust angle of attack for box blade from seat
  3. lengthen/shorten top link to make hooking up 3ph implements sooooo easy. I fabricated a PVC pipe connection and joint running the rear window of my cab so I can adjust top link while hooking things up.
I used a regular hydraulic cylinder, fabricated connectors for attachment to tractor 3ph top and to the implement. It is actually a MUST HAVE add-on, IMHO. Very worth the cost.
/ M5040 Hyd Top Link ? #9
Stu
Stu,
So you have quarter inch lines and one has a male pioneer end and the other a pioneer female end? I'm not sure what you mean by getting a double male end.
Any way, here's a pic of my remotes and set up. When I installed the tractor remotes I noted that they were Snap Tite 72 series branded female couplers. I went to the dealer and they figured I'd need two 1/4" male quick connects for the hose ends for the HTL. The male ends I needed were the ones I linked to above. They are compatible with the ISO 7421-1B standard. I did get mine from the dealer but for over $12 per male end. I'm sure your dealer could get what you need, but if you wanted to save a few $$ you could order two male ends from Discount Hydraulic hose. If you're lines are 1/4", then you'd need QC's with 1/4" NPT female ends to thread onto the 1/4" hose.
On the other hand, if you're dealer is close enough, it's probably easiest to just bring the HTL and hoses in and they should be able to give you the correct male QC's for a factory M remote setup. But, again, they should be the same as the type I linked to.
Stu,
Chris,
The 1/4" line has the threaded Male end for the Pioneer fitting, the other end is threaded Female fitting to connect to the Top Link fittings which are also Female.... hence the double Male fitting.
The difficult part will be connecting to the Factory Remote fittings..... they don't appear to be your typical quick-disconnect type... they don't have the sleeve to pull back.... kinda hard to describe....
I will probably just go ahead and take the top link and hoses to the dealer and ask them to assist in either providing me with the correct fittings, or tell me what I need to get to be able to attach to the factory rear remote fitting.
I'll try and get a pic or 2 tomm of the factory rear remote to give you an idea of what I'm talking about.
Stu
/ M5040 Hyd Top Link ? #11
Chris,
Stu
I think that you will find that a std 1/2" QD fitting will work. How to connect-disconnect. Just push the male fitting in to connect. To disconnect, push in and then pull out, all in one quick motion.
Hope that this helps you.
/ M5040 Hyd Top Link ? #12
Chris,
Stu
Hmm, I thought all hoses came with male ends on both sides. I'm surprised CC&MM didn't give you everything you need to connect the hoses to the cylinder/top link. All my hose and top link fittings were 1/4" NPT. I bought 90* swivels to connect the hose to the top link.
Sounds like your factory QC's are different for the M vs the BX since mine have the pull back collar on the female side.
Here's a 90* elbow with 1/4 NPT male ends on both sides, but it's not a swivel fitting. Of course this assumes your hoses and top link are NPT compatible.
https://www.surpluscenter.com/item.asp?UID=2009071107240128&item=9-5500-4-4&catname=hydraulic
Surprised that no one with an M who's added the CC&M HTL has chimed in. You're probably best to take it to your dealer or a local hydraulic shop. Since I made mine up from Surplus Center stock, I knew what I was dealing with except for the male QC's which my dealer helped me with.
/ M5040 Hyd Top Link ? #13
Stu
Standard Pioneer fittings will fit! They might have sent you Deere fittings instead. Go to Tractor Supply....
Ok... I think based on what you guys have said that I can get this remote installed.
Here are some pics of the rear remote, and also the kit that I was sent from CC&M.
I think I need the correct remote fittings, which I hope are the one in the TSC link below, and then all I should need are some 90deg fitting to connect the hose's to the top link.
Let me know what you guys think.
Stu
Pioneer 1/2 in. Standard ISO Tip, 3/4 In., 16 ORB, Fits All Current Models, Poppet - 1824180 | Tractor Supply Company
/ M5040 Hyd Top Link ? #15
Guess I'm a little confused. I thought your Kubota factor female remotes were not pioneer so I don't follow how buying the male pioneer fittings from TSC will work with them. If you replaced the rear factory remotes with female pioneer of the same size, that should work Then all you'd need is a male to male coupler to go between the top link and hoses, or between the hoses and the pioneer male QC's. I looks like the male side of the hoses CC&M sent you would thread right into the Top link block.
What I was trying to spec for you is the male QC's compatible with your factory female QC's but given the M set up is different than the BX, the one's I linked to at discount hydraulic hose might not work for you. If the female factory QCs have Snap Tite 72 Series embossed on them, then the one's I linked to would work.
It's become apparent to me that the factory rear remotes are not Pioneer.
The only marking on them is "Parker 0312-001"
I guess I will just have to see what my dealer can set me up with.
I'm disapointed that there doesn't appear to be anyone here with a M 40 series tractor who has installed a Hyd Top Link to there factory rear remotes.
Stu
/ M5040 Hyd Top Link ? #17
Stu
the rear remotes on my m8540 accept 1/2" male pioneer fittings.
It's WORKING!
Just wanted to thank everyone who stated that the Pioneer fittings should work..... they did!
I went to the dealer this morning and took what I had and asked the service guys if this was what I needed.......they said it sure was..... I said OK.... show me on one of these M Models how to connect the Pioneer fittings.... they grabbed'em..... and popped them right into the rear remotes......... DANG........why doesn't it do that on my tractor???? I noticed on the tractor at the dealer that the couplings were springing free when they pushed the couplings in......hmmmmm.
I got home and saw that my couplings did not spring free like at the dealer........found my rubber mallet.... a few taps on the end of the couplings........and they were free.......then my Pioneer couplings popped right in place!
I went ahead and picked up some 3/8" double male hyd fittings to connect the hoses to the top link and got them connected.
I did have to grind a little bit on the top link so it would fit into where the top link pin is, and also had to use the middle hole on the tractor top link connection instead of the top one because the Hyd Top Link end is so much larger then the threaded top link.
Got everything hooked up and even though it was somewhat frustarting I'm glad it all worked out.
Thanks for everyones assistance!
Stu
/ M5040 Hyd Top Link ? #19
Do you have pics of the finished project, Stu?
I always like pictures! LOL
2017 Ford E-Series FedEx Delivery Truck, 5.4L V8, Step Van Conversion (A63689)
2017 Ford E-Series...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A64194)
2013 Chevrolet...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
1995 Landoll 55 Ton Trailer (A60352)
1995 Landoll 55...
