Lynch Pins Coming Off
   / Lynch Pins Coming Off #151
A careful wrap and twist of black iron wire will secure those pins.
I'm a fan of zip-ties...
I have had the same problem when mowing some heavy trashy fields. Since I started using the ties, I haven't lost a single one.
   / Lynch Pins Coming Off #152
Regretfully, I have had zip ties get broken or come off. This happens when I work in the woods, where branches and stuff hit the pins. For my brush cutter, I use bolts and double nuts now. For my quick hitch, which I use for logging, I have gone to heavy duty lynch pins, which required me to bore out the main pins to accommodate the diameter. These are like mouse traps, so one has to be careful using them. So far, they have worked. Where I don't need frequent removal, such as a drawbar on the quick hitch, I use bolts and double nuts.
   / Lynch Pins Coming Off #153
If you have QH compatible implements....get a QH
Then the pins that hold the QH on.....use bolts and nylocks because removing and swapping is a MUCH less frequent thing....and possibly never if ALL your implements are QH compatible
   / Lynch Pins Coming Off #154
Alas, that is not the case. My tractor has a category 1 hitch that has dual diameter ball ends so it will fit Cat 2 implements, but the spacing is still cat 1. My 8' dual spindle brush cutter is cat 2. My carryall modified to have a 60 cubic foot firewood box is cat 1. I opted for the Cat 1 QH, so it only works for my woodbox and for dragging logs. And it actually is not easy to mount the woodbox. Everything has to be perfectly aligned, which takes some time.
   / Lynch Pins Coming Off #157
Re post 47. This lynch pin is a cheap type. The giveaway is there is no bend on the ring where it enters the pin head so the ring ends go in at an angle. This lets in dirt that gums things up making the ring stiff and sit out slightly from the pin exactly as in post 47 photo.
The best / reliable type are the ones with a bent end on the ring to ensure the end goes into the pin "square" and this seems to keep the dirt out as well, so it is rare for the pin to get stiff, and not sucure properly.
   / Lynch Pins Coming Off #158
I use those black lynch pins on all the connections. They snap so tight -like getting your fingers caught in a rat trap.
I secure the lower lynch pins with black nylon zip ties. Never lost one yet.
405 (A52706)
405 (A52706)
2025 Safety Basket Forklift Attachment (A59228)
2025 Safety Basket...
1000000 (A47477)
1000000 (A47477)
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
*Selling at Royal Auction Zephyrhills, FL Location* Year: 2005 Make: Mitsubishi Fuso Model: FE84D (A59230)
*Selling at Royal...
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
