Lynch Pins Coming Off
   / Lynch Pins Coming Off
When you all were talking about safety wire my mind went to rebar wire ties. They are very cheap and quick. The aviation wire tire is better but expensive. This video will show them on rebar but transfer the info to the lynch pins.
That was a really cool video and great to know. Thanks for sharing!
   / Lynch Pins Coming Off #142
Fixit 1
I use flat washers on mine between the arm or link & the lock pin. I have noticed the arm or link works the lock pin out of the hole in the pin. It works for me, also a little squirt of Fluid Film on the pins seems to help. Cheers!!
I hadn't had any issues until I got my flail. It was using hair pins and I'd lost one of those: I tried hunting down replacement link pins but was unscuccessful, so stuck with these hair pins. They seemed a little on the small side and I got to wondering whether it didn't get ground up in the manner that you describe. I started using washers and have not had an issue since. Well... I did have a top link pin pop out after a crappy/weak lynch pin I was using decided it had had enough: nothing hitting that pin up there; it just popped out because of a lot of action with the floating top link connection there (and I have a shimmed up cat1 pin in a cat2 top link hole on the flail).
   / Lynch Pins Coming Off #143
I have put this story on here before. And it really wasn't the lynch pin but the result would be the same.
About twenty years ago my then 70-something mother called me and in a panicked voice told me to come to her house right now. I figured she had shot somebody or something and broke all speed limits getting there. To make a long story short the lynch pin hadn't come off, but the nut holding the bolt on the left 3-pt had come off. The result was the same as the lynch pin being lost. She had reached the end of the field and turned sharply holding the left brake and the mower had caught on the left tire. By the time she got the tractor stopped the mower was resting against the left time and the blade had cut thru the tire three times. When I got on the tractor, and a 4600 Ford is tall for it's hp, I could reach out my arm and grab the blade while facing forward on the tractor. Had to pull the mower off the tractor with my truck, have a guy come out and replace the tire, and straighten the lower arms using a torch.
When mowing I check my pins every time I get off my tractor.
RSKY
Anyone who has a Kioti NX (not sure about other models) needs to check the keeper bolts holding the pins for the link arms: I loctite'd mine (gave recommendation to dealer to do the same- who removes them?) I had one pop out and the pin came out (fortunately it shot out and on to the ledge under the PTO, where the drawbar goes). Looked back while running up a slight bank to see the rear corner of the brush hog toward the top of the rear tire! BH wasn't engaged but it still freaked me out. I had been wondering why the BH had been scalping a bit and I had to keep adjusting (whenever something doesn't seem right it's because it's probably NOT right!).
   / Lynch Pins Coming Off #144
It started out as a jerry rigged solution but I’ve had good luck with 4 gauge copper ground wire for pins. You can bend it in place without tools and I’ve not had anything close to the problems with it coming off vs Lynch pins. A bolt and nylon nut is the most durable solution but also the hardest to install/remove.
   / Lynch Pins Coming Off #145
I've mentioned this earlier but a picture is worth 1000 words. These are easy to make and use and easily prevent the lynch pins from being pulled out by branches and weeds. Also no tools needed.
   / Lynch Pins Coming Off #146
What is it made of, is it just a big washer and a cut-off piece of 2" pipe?
   / Lynch Pins Coming Off #147
A large 1" washer with a piece of 2 1/2" OD muffler pipe welded on. The washer also has a 2 1/2" OD. Each piece of muffler pipe is ground out to fit a particular lynch pin setup. You'll notice in the second picture that the washer is tilted to enable the lynch pins removal. If the washer isn't tilted the lynch pin won't come out. It's a bit of a pain installing the lynch pin until you realize that the washer needs to be tilted just a little less before the lynch pin will slide in. Also everything needs to be alligned just right for the lynch pin to be removed. The chances of that happening I figure are pretty remote.
   / Lynch Pins Coming Off #148
   / Lynch Pins Coming Off #149
Had run my 8' finish mower for the last year without any issues. With a guide wheel on each corner, a total of 4 lynch pins had been holding everything tight...
Then, I read this thread!
Sure enough, the next day while using the mower, I lifted it and one of the guide wheels fell out! Lost a lynch pin mowing under some overhanging brush...
Jinxed!!!
Walked back along the mowing path and luckily found the spacers and spindle bushing.
All four wheel spindles are bolted and double nutted now.
   / Lynch Pins Coming Off #150
There are several posts about this but not many recently so a new day means new ideas. When I brush hog a different lynch pin falls off nearly every time. I've brush hogged five times in the last two months and have lost four lynch pins.
Facts: I do have a lot of overgrown weeds and saplings and I do use the HD black lynch pins.
My question is how do I keep them from coming off? I don't care about losing them so much as I do about tearing up my equipment. Chaining them to somewhere on the tractor just keeps me from losing the pin but it doesn't stop the inevitable damage from the pin coming out. Is there a better more secure pin out there other than a bolt and nut? Duct tape? Key rings? Thanks in advance for any and all suggestions.
The 1st time my flail mower disconnected on one side because the lynch pin fell out, I stopped using them. I use bolts and lock washers now for peace of mind.
   / Lynch Pins Coming Off #151
A careful wrap and twist of black iron wire will secure those pins.
I'm a fan of zip-ties...
I have had the same problem when mowing some heavy trashy fields. Since I started using the ties, I haven't lost a single one.
   / Lynch Pins Coming Off #152
Regretfully, I have had zip ties get broken or come off. This happens when I work in the woods, where branches and stuff hit the pins. For my brush cutter, I use bolts and double nuts now. For my quick hitch, which I use for logging, I have gone to heavy duty lynch pins, which required me to bore out the main pins to accommodate the diameter. These are like mouse traps, so one has to be careful using them. So far, they have worked. Where I don't need frequent removal, such as a drawbar on the quick hitch, I use bolts and double nuts.
   / Lynch Pins Coming Off #153
If you have QH compatible implements....get a QH
Then the pins that hold the QH on.....use bolts and nylocks because removing and swapping is a MUCH less frequent thing....and possibly never if ALL your implements are QH compatible
   / Lynch Pins Coming Off #154
Alas, that is not the case. My tractor has a category 1 hitch that has dual diameter ball ends so it will fit Cat 2 implements, but the spacing is still cat 1. My 8' dual spindle brush cutter is cat 2. My carryall modified to have a 60 cubic foot firewood box is cat 1. I opted for the Cat 1 QH, so it only works for my woodbox and for dragging logs. And it actually is not easy to mount the woodbox. Everything has to be perfectly aligned, which takes some time.
   / Lynch Pins Coming Off #157
Re post 47. This lynch pin is a cheap type. The giveaway is there is no bend on the ring where it enters the pin head so the ring ends go in at an angle. This lets in dirt that gums things up making the ring stiff and sit out slightly from the pin exactly as in post 47 photo.
The best / reliable type are the ones with a bent end on the ring to ensure the end goes into the pin "square" and this seems to keep the dirt out as well, so it is rare for the pin to get stiff, and not sucure properly.
   / Lynch Pins Coming Off #158
I use those black lynch pins on all the connections. They snap so tight -like getting your fingers caught in a rat trap.
I secure the lower lynch pins with black nylon zip ties. Never lost one yet.
Towable Centrifugal Water Pump (A59228)
Towable...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
KUBOTA KX057-4 EXCAVATOR (A59823)
KUBOTA KX057-4...
