lukinjohn
/ lukinjohn #1
lukinjohn
mt
craftman
Hi I have a 24 hp B & S,with Nikki carb,what would happen if you took the gas shut off solenoid off and put a plug were it was,thanks for the information,lukinjohn
/ lukinjohn #2
The engine will likely "diesel" after the key is turned off .
/ lukinjohn
Hi Mostly Gas,,thanks for reply,I was just wondering,thats the first one I seen ,thanks again lukinjohn
/ lukinjohn #4
It will backfire when you shut it down for one thing, the way it is now it has to open to allow fuel in also.
/ lukinjohn
Hi TOPPOP52 THANKS FOR THE REPLY,LUKINJOHN
/ lukinjohn #6
No problem, if you eliminate the valve, which I wouldn't, you will need to provide a way to cut the fuel off when you shut down the engine.
/ lukinjohn
Hi Toppop52,,will order new one,must stick,once and awhile have checked it if I put 12volts to it it works most of the time but sometimes it doesn't open ,running now,thanks for the help Louie
/ lukinjohn
Hi TOPPOP52 I will let you know what happens thanks again for the help Louie
2015 Ford F-450 4x4 Crew Cab Utility Flatbed Truck (A64556)
2015 Ford F-450...
2020 Chevrolet Tahoe SUV (A64557)
2020 Chevrolet...
Barrel (A64557)
Barrel (A64557)
1989 Heil MC 307 Insulated 6,500 Gallon T/A Chemical Tanker Trailer (A64194)
1989 Heil MC 307...
2014 Kenworth T370 21ft. Flatbed Truck (A64194)
2014 Kenworth T370...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
