lukinjohn
/ lukinjohn #1
lukinjohn
mt
craftman
Hi I have a 24 hp B & S,with Nikki carb,what would happen if you took the gas shut off solenoid off and put a plug were it was,thanks for the information,lukinjohn
/ lukinjohn #2
The engine will likely "diesel" after the key is turned off .
/ lukinjohn
Hi Mostly Gas,,thanks for reply,I was just wondering,thats the first one I seen ,thanks again lukinjohn
/ lukinjohn #4
It will backfire when you shut it down for one thing, the way it is now it has to open to allow fuel in also.
/ lukinjohn
Hi TOPPOP52 THANKS FOR THE REPLY,LUKINJOHN
/ lukinjohn #6
No problem, if you eliminate the valve, which I wouldn't, you will need to provide a way to cut the fuel off when you shut down the engine.
/ lukinjohn
Hi Toppop52,,will order new one,must stick,once and awhile have checked it if I put 12volts to it it works most of the time but sometimes it doesn't open ,running now,thanks for the help Louie
/ lukinjohn
Hi TOPPOP52 I will let you know what happens thanks again for the help Louie
2022 CATERPILLAR 313GC EXCAVATOR (A65053)
2022 CATERPILLAR...
2024 Texoma 16ft. T/A Equipment Trailer (A64194)
2024 Texoma 16ft...
2004 Harmon Steel Barrel Asphalt T/A Tanker Trailer (A64194)
2004 Harmon Steel...
2017 Ford F-150 Pickup Truck (A64556)
2017 Ford F-150...
2010 RU SYSTEMS SMART 850 SIGN TRAILER (A66091)
2010 RU SYSTEMS...
SWINGTEC D-88307 COLD FOGGING APPLICATOR (A64276)
SWINGTEC D-88307...
