lukinjohn
/ lukinjohn #1
lukinjohn
mt
craftman
Hi I have a 24 hp B & S,with Nikki carb,what would happen if you took the gas shut off solenoid off and put a plug were it was,thanks for the information,lukinjohn
/ lukinjohn #2
The engine will likely "diesel" after the key is turned off .
/ lukinjohn
Hi Mostly Gas,,thanks for reply,I was just wondering,thats the first one I seen ,thanks again lukinjohn
/ lukinjohn #4
It will backfire when you shut it down for one thing, the way it is now it has to open to allow fuel in also.
/ lukinjohn
Hi TOPPOP52 THANKS FOR THE REPLY,LUKINJOHN
/ lukinjohn #6
No problem, if you eliminate the valve, which I wouldn't, you will need to provide a way to cut the fuel off when you shut down the engine.
/ lukinjohn
Hi Toppop52,,will order new one,must stick,once and awhile have checked it if I put 12volts to it it works most of the time but sometimes it doesn't open ,running now,thanks for the help Louie
/ lukinjohn
Hi TOPPOP52 I will let you know what happens thanks again for the help Louie
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
2012 Kenworth T300 17ft. Cab and Chassis Truck (A64194)
2012 Kenworth T300...
Dixie Chopper Zero Turn Commercial Mower (A64553)
Dixie Chopper Zero...
2005 IC Corporation PB105 School Bus (A64194)
2005 IC...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2022 EZ-GO ELITE...
