lukinjohn
/ lukinjohn #1
lukinjohn
mt
craftman
Hi I have a 24 hp B & S,with Nikki carb,what would happen if you took the gas shut off solenoid off and put a plug were it was,thanks for the information,lukinjohn
/ lukinjohn #2
The engine will likely "diesel" after the key is turned off .
/ lukinjohn
Hi Mostly Gas,,thanks for reply,I was just wondering,thats the first one I seen ,thanks again lukinjohn
/ lukinjohn #4
It will backfire when you shut it down for one thing, the way it is now it has to open to allow fuel in also.
/ lukinjohn
Hi TOPPOP52 THANKS FOR THE REPLY,LUKINJOHN
/ lukinjohn #6
No problem, if you eliminate the valve, which I wouldn't, you will need to provide a way to cut the fuel off when you shut down the engine.
/ lukinjohn
Hi Toppop52,,will order new one,must stick,once and awhile have checked it if I put 12volts to it it works most of the time but sometimes it doesn't open ,running now,thanks for the help Louie
/ lukinjohn
Hi TOPPOP52 I will let you know what happens thanks again for the help Louie
12ton Hydraulic Bottle Jack (A64557)
12ton Hydraulic...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
HARDEE 300 GALLON SPRAYER (A64278)
HARDEE 300 GALLON...
2022 JOHN DEERE 350G LC EXCAVATOR (A65053)
2022 JOHN DEERE...
2014 BOBCAT T650 SKID STEER (A65053)
2014 BOBCAT T650...
2015 Mack GU713 T/A Day Cab Truck Tractor (A64556)
2015 Mack GU713...
