LUCKNOW 78"-5030HSTC
/ LUCKNOW 78"-5030HSTC #1
5030
Rest in Peace
SE Michigan in the middle of nowhere
Kubota M9000 HDCC3 M9000 HDC
LUCKNOW 78\"-5030HSTC
I finally got my camera back from the in-laws.
Took some pictures of the new Lucknow 78" rear mount blower on the 5030HSTC. This blower looks real industrial. Check out the hydraulic rotator and the height of the discharge chute.
I will have to be careful about where I point that chute. I have a feeling that the volume of snow as well as the discharge distance is going to be pretty good. The impeller is 2 times as large as the Woods was.
The kids across the road are really bummed out. They know that the school bus will be coming for them no matter how drifted the snow gets.
We have had some 6 foot drifts here in the past. The 60" Woods I had before couldn't cut that deep of snow. besides, it wasn't wide enough for the 5030. It worked fine on the 3710, but the 3710 didn't have a cab or heat!!!
Re: LUCKNOW 78\"-5030HSTC
Here is another picture, from a different angle.
Another picture. I wanted the unit in orange, Kubota orange to be exact, but Helm Welding must only have blue paint. Would go good on a New Holland (uch)!!!
Here is a picture of the hydraulic chute rotator, lines and actuator cylinder.
I never have to get out of the cab. I can listen to a C.D., enjoy the heat and rock on......Ah yes, snow removal is shirtsleeves, slacks and Dockers.
I am playing at being a yuppie!!
/ LUCKNOW 78"-5030HSTC #5
maybe it's me, the camera angle or? But, that upper link on your 3pt seems awful small to hold up that big blower. Pic must be deceiving, huh?
Another picture, the most important part, the name plate!!!
This blower was actually cheaper for it's size than my Woods was and it's much more heavily constructed. The Lucknow weighs around 1300 pounds. About a third again as much as the Woods. This blower also has grease fittings on the auger shafts and idlers.
lamarbur:
It must be the camera angle. It does look rather puny in the picture. The blower is most certainly not puny though.
The top link is extended pretty far. We will see how it holds up. If it pukes, I'll get another, bigger one.
I don't know why, but the top link is category 1 on the tractor end and category 2 on the implement end. I'd prefer cat II on both ends but that will necessitate re machining the mounting plate at the transmission case. Not that it's beyond my means. It's a simple machining job, I am just putting it off until something breaks.
/ LUCKNOW 78"-5030HSTC #8
when I use to run digital computers into Ottowa Canada three times a week, that's all one would see. It is definitely the high end in blowers. Must be the angle of picture but I am sure you won't have any problems with it other than maybe some adjusting
lamarbur:
I might get my chance, soon. It's snowing here about an inch per hour. I checked weather.com and there is a white blanket that extends past Omaha and is tracking right down on us.
I can see that I am going to have to make some modifications on the Lucknow next summer. The skid shoes are underneath. I am going to add some outboard shoes on the inside edge of the blower side sheets. I made a set for the woods and hard rodded the bottoms. I think I'll do the same here. Also, it doesn't have a scraper/wear bar at the leading edge of the vertical sheet. I think an addition of an old county plow wear bar would work fine. Finally, the top of the chute needs a rubber deflector. The holes are there so I will grab a truck mud flap and make one. Sometimes I don't want the snow to go a hundred feet, I want to just pile it next to the blower like when I do the access lane to the horse barn. Other than those three mods, the thing is built like a tank.
I hope the 5030 is up to the task. I almost opted for twin augers. I could have increased the feed rate with two but I thought it would tax the tractor too much. The Lucknow is rated for up to 100 pto.
/ LUCKNOW 78"-5030HSTC #10
Daryl
What is the depth and diameter of the drum that the impeler sit in?
What was the cost?
I'll have have to snap some pics of my Pronovost.
/ LUCKNOW 78"-5030HSTC #11
<font color="blue"> I wanted the unit in orange, Kubota orange to be exact </font>
Something like this? I ran out of paint before I could do the touch-up. See attachment.
Don
Rowski:
I replied to you by private mail, but I will list the specifications here too.
The auger is 71" long. The difference between the 71" and the 78" is the stub shafts and the greaseable pillow blocks.
The auger is 14" in diameter, has fast flighting and the flighting is made from 1/2" X 1 1/2" steel.
The impeller/fan is 2 feet in diameter and is 7" from the back sheet to the kicker weldments The clearance between the impeller and the drum itself is about 1/8" on the circumference and about 1/2" between the back sheet and the weldment itself.
The chute opening, measured just inside the blower housing at the top of the fan is 10" X 8".
The gearbox is rated at 100 horsepower and the drive chain is 530.
She is built for some heavy duty punishment. I don't think an occasional rock will hurt it.
I could have opted for dual augers, one high and one low. That would have increased the feed rate but required more ponies. If I ever buy a bigger tractor (ha! ha!) I can re-fit the blower with the twin screws. /forums/images/graemlins/laugh.gif
The blower was $2200.00 delivered.
Don:
That's exactly what I had in mind. Now, you want to come down and do the job this summer? /forums/images/graemlins/confused.gif
Actually, we should have a local TBN meeting at my farm. We have quite a few members living around here too. /forums/images/graemlins/blush.gif
Somehow, that "blue" blower doesn't look right on an orange Kubota?? /forums/images/graemlins/shocked.gif
By the way, guys, I am really disappointed. We got about 3" of snow and some freezing rain. Not enough to bring the blower out. /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
It was enough to "disable" the Monroe County Road Commission, however!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ LUCKNOW 78"-5030HSTC #15
REALLY IMPRESSIVE snow mover. If you are worried about the BLUE on the back perhaps you can paint the fel GREEN and feel right at home in all the forums.
/ LUCKNOW 78"-5030HSTC #16
<font color="blue"> Now, you want to come down and do the job this summer? </font>
I have a tendency to get carried away with the paint brush. You'd probably end up with something like......see attachment /forums/images/graemlins/grin.gif
Don
/ LUCKNOW 78"-5030HSTC #17
maybe we could all go out and collect the little snow we have and bring it to 5030's house. Then he would have enough to try out his new LuckNow.
You need to sugest to the Lucknow company that they make a orange model,so it can cordinate with your Kubota.
next think you know there will be guys on JD with an blue snow blower, and an orange blade in the front
Don:
That view would probably look right at home in Detroit, around Mack and Kercheval!!
ledebuhr1:
When I ordered the blower, this fall, I requested it to be painted orange. I would have taken even an Allis orange or a Massey orange.
New Holland blue is a little hard to swallow. I have a NH bailer. It's red.
/ LUCKNOW 78"-5030HSTC #20
We use that same Lucknow behind the IH 584 and it works well. A slip clutch would save breaking all those shear bolts but what can ya do.
The one we use is about 20 years old but looks identical. Someone replaced the chute rotator cylinder and it was too long so I have rewelded the arm where the cylinder broke it off.
(2) 5' TRAILER RAMPS (A64280)
(2) 5' TRAILER...
2017 GMC 3500 Enclosed Service Body Truck (A62613)
2017 GMC 3500...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2020 TIGERCAT 234B LOG LOADER (A64276)
2020 TIGERCAT 234B...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
24in excavator tooth bucket (A61307)
24in excavator...
