LSD or ULSD
/ LSD or ULSD #1
liberty2701
Platinum Member
Lakes region,NH
Kioti Dk50se hst
I still have a choice where I live to either purchase off road diesel which is ulsd or heating oil which is lsd. What am I better off purchasing for my Kioti tractor. It is tier 3 and no where does it state ulsd. It only says diesel. No2 above 14f and no1 below 14f. Ulsd is about 3 cents more a gallon. What do you think?
/ LSD or ULSD
I think I stated it wrong. I meant to say No2 heating oil is LSD.NH has not switched over to ULSD for heating oil. I can still get deliveries of No2 LSD and use it in my tractor. Is it better?
/ LSD or ULSD #5
Your state has not yet changed over to ULSD for heating oil but eventually will. ULSD is all we can get here in NY.
If your tractor is a tier 3 or older either LSD or ULSD will work fine. If your tractor is a tier 4 tractor (new in past couple of years) it requires ULSD.
/ LSD or ULSD #7
Not sure what advantage using more sulfur in diesel would be. Even the engine manufacturers have extended oil drain requirements now that ULSD is pretty much standard. Sulfur just creates sulfuric acid and sulfur dioxide in the engine. Now, for it's lubricating qualities, which is questionable, most every engine made in this century has components that are designed around ULSD. And a lot of places are now putting biodiesel in the mix in some percentage. A 2% biodiesel blend alone will raise the lubricity to pre ULSD levels. Even more and the lubricity will exceed LSD levels. But if it makes you feel good, then go ahead and get the LSD fuel. Whatever you do, base it on sound reasoning and not some wive's tales about ULSD. Hint, hint.... it wasn't the sulfur that was the lubricity agent. The process used to remove sulfur from diesel also removed many of the lubricity agents from diesel. Federal fuel standards mandate that some lubricity be added back in to meet minimum standards.
/ LSD or ULSD #8
use either ... and for peace of mind , add some 2 stroke oil (any kind) ... couple of ounces ... any is better than none ....
/ LSD or ULSD
/ LSD or ULSD #11
I have seen that article. If you notice NH is not mentioned since NH has not decided to switch over to ULS heating oil (Live Free or Die)I confirmed it with my oil supplier. If the consensus is sulphur is bad than I will not use it.
Sulfur is bad for the environment but not necessarily for your engine. As long as you change the oil as required, it should not be an issue with either LSD or ULSD fuel. All new engines are designed to run on ULSD so in your case, use what ever you want.
If you want to save $3 per hundred and put a little more pollution in the air, that is your business. Your tractor for sure wont be producing as much pollution as a home heating unit simply because of less fuel burned.
/ LSD or ULSD #13
and look on the bright side ... you're doing your part to help raise winter temperatures and reduce snow falls ... yaaaahhhh for global warming...
/ LSD or ULSD #14
I paid the extra for ULSD in the tractors as soon as it came on the market . It was worth it just to get rid of the sulphur stink.
/ LSD or ULSD #15
Do you smell that? It's diesel fuel son. Nothing else in the world smells like that. I love the smell of diesel fuel in the morning. It smells like....victory.... :D
/ LSD or ULSD #19
LOL ...
2022 Seppi MINIFORST CL 175 Skid Steer Forestry Mulcher (A65640)
2022 Seppi...
2025 DELCO T/A 24FT GOOSENECK TILT DECK TRAILER (A67148)
2025 DELCO T/A...
2022 EZ-GO ELITE...
2018 Ver-Mac S/A Solar Towable Speed Trailer (A64194)
2018 Ver-Mac S/A...
2013 INTERNATIONAL DURASTAR 4400 FORESTRY BKT TRK (A63276)
2013 INTERNATIONAL...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
