Don i would recommend the 6 inch bit for your job if you have a post over 6 inches (maybe a couple) use hand hoe digger to increase size, the Titan forks are not the quality of everything attachments and not as expensive either and they have done the job for me.
I installed a set of remotes on the rear of my tractor and bought a cheap grapple from Ebay ran two 3/8 hoses from the rear remotes to the front of the tractor and operate the open and close of the grapple with my remotes instead of a $900 + 3 function valve (and that price would with me installing it) It cost $120 for everything to hook it up,the grapple is one of the best attachments i have and most useful.
I will probably get flack fo buying cheaper attachments but i dont need attachments that built for commercial use i only need them every now and then.
There is a LS dealer that has u tubes on how to install rear remotes and 3 function valve go to Simple Country Tractor and check out their u tubes
I also use the rear remotes operate a hydraulic cylinder for my top link to be able to adjust my top link on the fly.
