Loader LS XG 3135H Tractor Attachments
/ LS XG 3135H Tractor Attachments #21
It will work with a 12'' auger gonna take a couple weekends for a 100 posts, With the forks you can load up a bunch of posts Then just take them off as needed. If the auger gets wrapped around tree roots you have to back it out by hand
/ LS XG 3135H Tractor Attachments #22
I figured I would put a post in every 10 T Posts. I figured roughly 40 holes and 4 for the gates. I seen the 12 inch and 15 inch augers at MFA when I got off work today. I will shop around a bit more before I take the plunge.
One other question: Other than the obvious way how can I tell if my tires are air filled or foam filled. The guy a MFA asked and I assumed they were air filled. Is that a valid question or was he confused.
/ LS XG 3135H Tractor Attachments #24
You want liquid filled ( rim guard or windshield washer fluid ) rear tires for ballast
How do I determine what I have? I don't see any info on the tires.
/ LS XG 3135H Tractor Attachments #26
What are you fencing in cattle or horses ? I don't like t posts with horses too sharp big vet bills...
Both. We have had Tennessee Walkers for 30 or so years and never had an incidents. We did have one get cut on a piece of tin that blew off a turn of the century barn when we lived up in the Kansas City area.
/ LS XG 3135H Tractor Attachments #28
how can I tell if my tires are air filled or foam filled/ The guy a MFA asked and I assumed they were air filled.
I speculate 70% of compact tractor tires are filled with liquid.
Perhaps 25% of compact tractor tires are inflated with air. My Kubota compact tractor tires are inflated with air.
Perhaps 5% of compact tractor tires are filled with solid foam.
An experienced operator can discern the difference between air and liquid/foam filled rear tractor tires in a short period of operation.
For you, take off the cap, press on the center valve stem with a tool ----- and see/hear what comes out. "nothing" = foam
MORE: Comparing Types of Liquid Tire Ballast | OrangeTractorTalks
/ LS XG 3135H Tractor Attachments #30
Thanks for the tip on my profile. I updated some of my profile.
I Maybe putting in a 100 posts. as soon as the mud dries up a bit.
Don i would recommend the 6 inch bit for your job if you have a post over 6 inches (maybe a couple) use hand hoe digger to increase size, the Titan forks are not the quality of everything attachments and not as expensive either and they have done the job for me.
I installed a set of remotes on the rear of my tractor and bought a cheap grapple from Ebay ran two 3/8 hoses from the rear remotes to the front of the tractor and operate the open and close of the grapple with my remotes instead of a $900 + 3 function valve (and that price would with me installing it) It cost $120 for everything to hook it up,the grapple is one of the best attachments i have and most useful.
I will probably get flack fo buying cheaper attachments but i dont need attachments that built for commercial use i only need them every now and then.
There is a LS dealer that has u tubes on how to install rear remotes and 3 function valve go to Simple Country Tractor and check out their u tubes
I also use the rear remotes operate a hydraulic cylinder for my top link to be able to adjust my top link on the fly.
/ LS XG 3135H Tractor Attachments #31
I used/abused SSQA pallet forks until I got a grapple. Now I use/abuse the grapple for everything I used the forks for except for moving actual pallet loads. I found a medium duty grapple new at a skid stear attachment outlet place for $900. It’s my go to attachment along with the bucket.
/ LS XG 3135H Tractor Attachments #32
Don The way i have always filled my tractor tires buy a liquid water fill adapter HALTEC Metal Water Adaptor,for Liquid Fill Tires, N-191, Silver | eBay position the valve stem at 9 o団lock remove the valve stem (not the core the whole valve stem) attach the water valve cut apiece hose to screw on the fill adapter attach a funnel to other end of hose and fill with what you are going to use (windshield washer fluid does a good job) then hook water hose up for water fill. i use a quick connection on the fill adapter, as you fill with water the tire will pressure up ( use a floor jack to jack the tire up so fully extended) after it slows down taking water i pinch the water hose off and remove quick connector and let the air build up out, continue doing this until its at 9 o団lock or whatever position you decide.
/ LS XG 3135H Tractor Attachments #33
I agree neverfailyou it is about the handiest attachment i have and stays on my tractor most of the time. I also bought a 48 inch from MTL Attachments because this grapple has grease zerts on all moving parts and cost $890 MTL Attachments Kubota-Kioti Compact Tractor 48 Root Grapple Bucket-Free Ship | eBay
I have had this cheap grapple for over a year using it for everything with no problem.
The 55 inch from everything attachments cost more than double than this grapple and dont have grease zerts.
/ LS XG 3135H Tractor Attachments #35
I stand corrected
Thanks K5
Tires and Rims (A65640)
Tires and Rims...
2002 CHEVROLET 3500 FLATBED TRUCK (A60430)
2002 CHEVROLET...
Case 580 Super E Backhoe Loader (A66285)
Case 580 Super E...
2013 FREIGHTLINER Cascadia (A63689)
2013 FREIGHTLINER...
Connect CH65 Hydraulic Breaker Excavator Attachment (A64194)
Connect CH65...
2019 Ram 1500 Pickup Truck (A64556)
2019 Ram 1500...
