Loader LS XG 3135H Tractor Attachments
   / LS XG 3135H Tractor Attachments #31
Don i would recommend the 6 inch bit for your job if you have a post over 6 inches (maybe a couple) use hand hoe digger to increase size, the Titan forks are not the quality of everything attachments and not as expensive either and they have done the job for me.
I installed a set of remotes on the rear of my tractor and bought a cheap grapple from Ebay ran two 3/8 hoses from the rear remotes to the front of the tractor and operate the open and close of the grapple with my remotes instead of a $900 + 3 function valve (and that price would with me installing it) It cost $120 for everything to hook it up,the grapple is one of the best attachments i have and most useful.
I will probably get flack fo buying cheaper attachments but i dont need attachments that built for commercial use i only need them every now and then.
There is a LS dealer that has u tubes on how to install rear remotes and 3 function valve go to Simple Country Tractor and check out their u tubes
I also use the rear remotes operate a hydraulic cylinder for my top link to be able to adjust my top link on the fly.
I used/abused SSQA pallet forks until I got a grapple. Now I use/abuse the grapple for everything I used the forks for except for moving actual pallet loads. I found a medium duty grapple new at a skid stear attachment outlet place for $900. It’s my go to attachment along with the bucket.
   / LS XG 3135H Tractor Attachments #32
How do I determine what I have? I don't see any info on the tires.
Don The way i have always filled my tractor tires buy a liquid water fill adapter HALTEC Metal Water Adaptor,for Liquid Fill Tires, N-191, Silver | eBay position the valve stem at 9 o団lock remove the valve stem (not the core the whole valve stem) attach the water valve cut apiece hose to screw on the fill adapter attach a funnel to other end of hose and fill with what you are going to use (windshield washer fluid does a good job) then hook water hose up for water fill. i use a quick connection on the fill adapter, as you fill with water the tire will pressure up ( use a floor jack to jack the tire up so fully extended) after it slows down taking water i pinch the water hose off and remove quick connector and let the air build up out, continue doing this until its at 9 o団lock or whatever position you decide.
   / LS XG 3135H Tractor Attachments #33
I agree neverfailyou it is about the handiest attachment i have and stays on my tractor most of the time. I also bought a 48 inch from MTL Attachments because this grapple has grease zerts on all moving parts and cost $890 MTL Attachments Kubota-Kioti Compact Tractor 48 Root Grapple Bucket-Free Ship | eBay
I have had this cheap grapple for over a year using it for everything with no problem.
The 55 inch from everything attachments cost more than double than this grapple and dont have grease zerts.
   / LS XG 3135H Tractor Attachments #34
My 55" EA grapple has grease fittings.
   / LS XG 3135H Tractor Attachments #35
I stand corrected
Thanks K5
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2005 MERCURY Grand Marquis Sedan (A56859)
2005 MERCURY Grand...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
2014 BRENNER CRUDE TRAILER (A58214)
2014 BRENNER CRUDE...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
2017 Ford F-150 Pickup Truck (A55973)
2017 Ford F-150...
