LP quickhitch for bx
/ LP quickhitch for bx #11
I saw there is a QH05 that is for subcompact tractors. Do you have to use bushings on the lower link arms with this?
No Bushings needed with the QH05, I have one on my B2601 and it is a pleasure to hitch up implements using it. It is a lot lighter than the 70+ pounds of the Cat 2 QH's but the B2601 can not over use it so at 39lbs it should work great on you're BX.
Oh, it does come with a top link adapter.
/ LP quickhitch for bx #12
The LP comes with the top link adapter and lift arm bushings to bring the pins out to the same size as the hook recess. I bought the HF one also. It did not have the adapter or the bushings. i made the adapter with two pieces of flat bar and drilled the holes. I extended the top hook 3/4" so all implements fit it OK. I also replaced the bolts with pins. I made an attachment on the back of it, a bar that pins on to hook my suitcase weights on for ballast. My LP BH came with the adapter as they recommend using it with their implement. I buy bushings from LP for all my implements (hired help have a knack of losing them), either right length or the longest cut to length. Some older implements (not QH ready need the larger bushing for the top link that the QH ready implements already have. Saved a lot of money.
Ron
TANK MANIFOLD (A58214)
2011 WESTERN STAR  4900 SB (A60736)
2011 WESTERN STAR...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2005 Big Tex Utility Trailer (A60352)
2005 Big Tex...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
(INOP) MASSEY FERGUSON 451 TRACTOR (A59823)
(INOP) MASSEY...
