LP quickhitch for bx
/ LP quickhitch for bx #1
Tractorrr
TN
kubota bx 2370-1
I am considering the landpride quickhitch but was wandering if anyone has used this and if there are things to be aware of?
Does the hitch move the implement back further making it likely you will have to get a longer pto shaft and toplink?
Is it still easy to hook up on uneven ground or if you just leave the implement on the ground? Thanks
/ LP quickhitch for bx #2
I use the one from harbor freight. It will move the connection back. All of my PTO shafts had enough slip in them to work fine. The top link also busted adjusted out for releveling vertically a few threads.
It is easy to hook up on the ground but should be kinda level horizontal at the lower pins. I usually throw a block under the low side when setting one down for storage.
Look for the "top hook adaptor" also for those implements that are not QH compatible. About 25 bucks.
Don't get me wrong. I have a lot of landpride stuff. But the harbor freight one does everything that the LP one does at less than half the price.
/ LP quickhitch for bx #3
The implements for a BX are not very heavy.
Have you considered the purchase of a six foot, iron Spud Bar to help you leverage around implements that crucial 1/4" relatively easily?
Most Spud Bars have a ground tip designed to help with leverage. My local welding shop sells six different types of Spud Bars.
I seek the simplest solution first.
LINK: spud bar in Hand Tools | eBay
/ LP quickhitch for bx #4
Never used a real quick hitch but have Pat's quick hitch. Long PTO shafts like on mowers you'll probably be okay. Short PTO shafts like on tillers and fertilizer spreaders may be an issue, but a fertilizer spreader probably won't work with a quick hitch anyway (an advantage of the Pat's hitches). A longer toplink shouldn't be necessary with a quick hitch, but may be with the Pat's hitches, but it certainly would be advantageous to get one anyway.
/ LP quickhitch for bx #5
I have it with my BX and don't have any PTO shaft issues. They all had enough length built in already.
Only thing I don't like about mine is on the new BX2380, I got the rear remote kit and the QH actually hits one of the hydraulic plugs when fully raised. Will have to be very careful about this when I have anything hooked up.
I saw there is a QH05 that is for subcompact tractors. Do you have to use bushings on the lower link arms with this?
/ LP quickhitch for bx #7
I believe so. I bought a farm ex cat 1, no bushings needed. The nice thing about the qh05 is the spring loaded handles. you line up the implement and lift and it snaps in but you still have to mess with the top link so I don't think it's worth the extra money they ask for them.
/ LP quickhitch for bx #10
It doesn't look like that has the top link adaptor. I guess the adaptor is used for rotary cutters or finish mowers to allow for up and down movement of the mower?
It does not come with it but ranch ex makes one for $20.00 that I bought for it. Yes I use it for my bush hog.
/ LP quickhitch for bx #11
No Bushings needed with the QH05, I have one on my B2601 and it is a pleasure to hitch up implements using it. It is a lot lighter than the 70+ pounds of the Cat 2 QH's but the B2601 can not over use it so at 39lbs it should work great on you're BX.
Oh, it does come with a top link adapter.
/ LP quickhitch for bx #12
The LP comes with the top link adapter and lift arm bushings to bring the pins out to the same size as the hook recess. I bought the HF one also. It did not have the adapter or the bushings. i made the adapter with two pieces of flat bar and drilled the holes. I extended the top hook 3/4" so all implements fit it OK. I also replaced the bolts with pins. I made an attachment on the back of it, a bar that pins on to hook my suitcase weights on for ballast. My LP BH came with the adapter as they recommend using it with their implement. I buy bushings from LP for all my implements (hired help have a knack of losing them), either right length or the longest cut to length. Some older implements (not QH ready need the larger bushing for the top link that the QH ready implements already have. Saved a lot of money.
Ron
(2) John Deere Row Markers (A60462)
(2) John Deere Row...
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
1995 Landoll 55 Ton Trailer (A60352)
1995 Landoll 55...
Set 4 - 10-16.5 tires on wheels for bobcat (A61572)
Set 4 - 10-16.5...
2019 John Deere 1775NT Planter (A63111)
2019 John Deere...
