LowBoy or Deckover?
/ LowBoy or Deckover? #11
tey to stack a 2- wide set of round bales on a deck with fenders sticking up in the way.. :)
soundguy
/ LowBoy or Deckover? #12
my brother had to haul hay on a low trailer with wheel wells so he built up the bottom with lumber to make it flat and then dismantled it when the hay season was over.
/ LowBoy or Deckover? #13
i've seen pallates stacked between fender wells to do that too.
soundguy
/ LowBoy or Deckover? #14
I prefer my deckover gooseneck as it offers a broad, obstruction free surface to haul whatever suits my fancy. There are no fenders to bend, or get in the way when you go to tie down. Round bales are a perfect example.....
I don't find the height a problem. You need to be just as careful with your load 12" above ground as you do with it 30" above with regard to CG. Also, anything that you need a forklift to load on a deckover, you'll need a forklift to load on a lowboy.
Another consideration is dovetail ramps vs. a solid dovetail ramp vs. a tilt-deck, or a straight flat deck with detachable ramps. Lot's of different options....
Deck-on-neck is a nice option too for added storage space.
My sled trailer is also a deckover style, which is fantastic on the inside, but not as nice in terms of external cosmetics as a cargo or car-hauler would be. You need a deckover if you want to load sleds or quads side by side.
-Jer.
/ LowBoy or Deckover? #15
Tilt deck all the way for me!!
No need to mess with ramps or a gate, but if I get all nostalgic I can always leave the deck pinned and use ramps if I want.
/ LowBoy or Deckover? #16
Not sure if it might help or not, the trailer i bought a few months ago is a deck over with 2 12K axles low profile, it sets about 31" from ground to top of boards. Some of my friends that haul there hay tractors around alot use the low-boy type, most of there tractors are 4x4 so they dont even use ramps, the trailer is just low enough to drive the tractor on to it.
Good luck
/ LowBoy or Deckover? #17
i'm thinking of adding a top deck on my neck. good place for supplies that would otherwise take up space on the main deck.
soundguy
-Jer.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 CATERPILLAR D3 CRAWLER DOZER (A62129)
2021 CATERPILLAR...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
Chevrolet 2500 Flat bed (A61307)
Chevrolet 2500...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A62129)
2007 CATERPILLAR...
