Low Buck grapple build
   / Low Buck grapple build #31
Ryan,
If you are considering going that way, there is a WR Long third function solenoid operated valve which I installed on the loader joystick. It is not foot operated, but finger controlled while operating the joystick.
If you're interested, I installed mine in this thread.
INSTALLING GRAPPLES, WR LONG VALVE, PLUMBING
hey everybody, well I finaly got around to picking up the 1 inch plate today, traced my patterns and got the brackets cut out, ended up cutting them out with a torch, plasma cutter would not handle the 1 inch thickness, brackets came out pretty good though, as you can imagine, I have some smoothing to do as the torch does not cut as smooth as plasma cutter, hope to finish smoothing tomorrow and maybe weld them on wednesday
   / Low Buck grapple build #33
I wish my cuts with a torch were that smooth. Looks like you don't even need a plasma cutter, maybe you need to send it to me. :D
Chris
Thanks for the compliments fellas, actualy I cheated and used a peice of 1/4 flat stock as a guide for the torch tip, I simply c clamped it in position and repositioned it as nececary. have been very busy this past month and have not had a chance to work on grapple, hope to finish it in the next couple of weeks, when I do , pics and vids of it in action
   / Low Buck grapple build #38
Nice job on the grapple. I just picked my new Tatro grapple and WR Long valve kit and will install it on my Kubota B7800 in the next few days. While it's very heavy duty I do wish it was as wide as yours.
I'm looking forward to seeing your completed project
   / Low Buck grapple build #39
Ryan03, i see you use the same ingenious method to remember which hose belongs to what port as i do... The coloured zip ties !!! ;)
   / Low Buck grapple build #40
You are doing a great job but I wonder if a heavy duty piece of bar running between the teeth wouldnt give you much more versatility for things like picking up rocks, or ripping scrub or posts out of the ground. I do have a little experience with this. I have a kubota with a 4in1 bucket that is just fantastic, but I usually cant exactly 'see' what I'm grabbing so I have to guess the position. That would be pretty hard if I just had a couple of skinny teeth to play with. And apart from the visibility i think the extra wide grip provided by a bar would open up a whole lot of useful options. Perhaps a bar is something you could add or remove with a few bolts as needed.
2 Cubic Yard Dumpster (A55851)
2 Cubic Yard...
UNUSED JCT 84" HYD 4N1 BUCKET (A57193)
UNUSED JCT 84" HYD...
UNUSED RAYTREE RMBD72S 72" HYD DRUM MULCHER (A57193)
UNUSED RAYTREE...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A55315)
2006 Magnolia Dry...
2015 Caterpillar TL642C (A53317)
2015 Caterpillar...
UNUSED WOLVERINE MSG-11-44W 44" HYD STUMP GRAPPLE (A57193)
UNUSED WOLVERINE...
