Mowing Loud Gearbox- FarmPro mower
/ Loud Gearbox- FarmPro mower #1
SteveM
Upstate NY
Kubota B7100DT
I purchased a FarmPro 4' cutter from Homier last week, travelling show - anyhow, all is well except that there is a pretty loud howl to the cutter- in fact when you turn the shaft by hand there is a tick tick feel - and if I turn it by hand as fast as I can, a rough growl is audible. At PTO speed, it is a reverberating wow wow wow etc. I put in 90wt gear oil, greased the shaft and wheel zerks. Did I forget something? Are the gears simply rough cast? Should I contact Farmpro for replacement parts (seems like a big pain)
Thanks
/ Loud Gearbox- FarmPro mower #2
PTO driven mowers/cutters are almost always operated with the tractor PTO speed set for 540 RPM. If you've mistakenly selected the 1000 RPM speed, it might explain the noises that you consider unusual.
//greg//
/ Loud Gearbox- FarmPro mower #3
Steve,
When I turn my 5' KK rotary cutter, by hand, it is very smooth and do not have any ticking or howling. I do that check before mounting to tractor, each time. Make sure you don't have the U joints at any extreme angle. If the sound is coming from the gear assemby, sounds like a bearing to me. I would call Homier, and start the discussion. If coming from below deck, make sure there isn't a stick or something else the blades are hitting on (ticking).
/ Loud Gearbox- FarmPro mower #4
Don't sound right,but never heard a farm pro one before,,probably somebody here has one and could say,,,,my 5ft kk,doesn't make a lot of noise,,but the blades spinning do make a pretty good sound,,yeah,make sure its on right pto speed and run it an hr or two,,,maybe it will get better or worse,either way,you'll know more,,,if its defective,and brand new,,to **** with parts and trying to fix it,,,get your money back or a new one,,,surely even farm pro won't expect you to keep a defective new mower,or try and fix it???? Let us know what they say when you talk to them,,,may help somebody else decide what to buy,,or what not to buy. thingy
/ Loud Gearbox- FarmPro mower #5
Seems like I replied to this earlier this morning.. now the post is gone.... hmmm...
Soundguy
/ Loud Gearbox- FarmPro mower #6
dont worry soundguy, your not losing your mind, it was in a different forum that he also posted the question
THanks for your replies so quick - sorry Soundguy, I knew you would repond - I wasnt getting much play up on the rich end of the board so I thought I would run down here where people actually know how to fix stuff /forums/images/graemlins/grin.gif
Additional information:
I was running at 540 RPM, and turning by hand at 10 RPM I can hear the growl building
I have a 5'KK on my Ford 9n - turns with no 'texture' by hand, way quieter in operation.
I ran it for 2hrs Sunday, no change in the sound, but I did get used to it /forums/images/graemlins/confused.gif My wife kinda looked at me funny accross the field when I kicked it in the first time....sounds like a train is comin' at ya....at least it will motivate the deere to get out of my way!
I will call Homier tomorrow and test their customer service...to be frank, I cant be sure it is the gears or a bearing in the blade assbly. I had read here that the farmpro tractor gears gave quite a whine when new, thought maybe this is the same issue....either way for $340 I am satisfied.
/ Loud Gearbox- FarmPro mower #8
Well,thats the main thing. thingy
/ Loud Gearbox- FarmPro mower #9
The noise is normal and unfortuneate, but you cant beat the price!
/ Loud Gearbox- FarmPro mower #10
Ok.. cool.. I was really wondering about that.
If you don't get a new one, and the nose is bothersome.. try some heavier oil like I mentioned. like outboard lube.. or even a pourable grease.. but not plain grease as that box wasn't meant for grease ( though the new HD howse boxes are.. )
Soundguy
/ Loud Gearbox- FarmPro mower #11
I don't think the noise is normal. Mine does not have any clicking while turning by hand. It is a very smooth feel with NO Metal to Metal noise.
/ Loud Gearbox- FarmPro mower #12
sevencorners,
Do you have a Farm Pro brush hog? They normally have a noisy sounding gearbox. I have sold a dozen or so of them and the last 4 or 5 months they have all been noisy, but they work. With everyon going so high on implement because of steel prices, the low cost of the Farm Pro units will save you enough for some ear plugs, I hope they get better gearboxes soon, I would pay an extra $ 40 or so for a higher quality gearbox.
/ Loud Gearbox- FarmPro mower #13
OR....just spend a couple hundred more and get a king kutter,,,,saving money is a good thing,,but.........whats a 4 ft king kutter cost now,,,500 dollars or so????thingy
/ Loud Gearbox- FarmPro mower #15
I have the same mower and get exactly the same sound you are describing. It is loud, but it does the job.
Thanks for all the comments, I put another 3hrs on it last weekend with good results. As for pricing, I paid about $200 less for this versus the king kutter, which is real money for an implement I use 20-25 hrs a year.
Now we will see how it stands the test of time /forums/images/graemlins/ooo.gif
Club Car Carryall 6 Medical Utility Cart (A64553)
Club Car Carryall...
Crane (A64194)
Crane (A64194)
2009 Chevrolet Silverado 2500 Crew Cab Pickup Truck (A64556)
2009 Chevrolet...
2013 KENWORTH T6 SERIES (INOPERABLE) (A65643)
2013 KENWORTH T6...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
PAIR OF TRACTOR TIRES AND RIMS (A65643)
PAIR OF TRACTOR...
