How Warm Should My Cutter's Gearboxes Get?
/ How Warm Should My Cutter's Gearboxes Get? #1
Liquidsilver
St. Louis
Kubota M5400
My six foot cutter has a gearbox that calls for 90wt gear oil. I would call it a noisy gearbox, generating a pretty noisy hum... but even on hot days cutting tall stuff, I'm surprised it never gets very warm. It's never given me a problem either.
I also have a fairly new (less than 20 hours) 10-foot, twin spindle cutter that has three gearboxes. The manufacturer says they're factory filled and maintenance-free. Recommended lubricant is EP-0 grease. These boxes seem very quiet.
BUT, Saturday I heard a strange squealing noise, looked back and the left gearbox is squealing and smoking, like rubber smoke. I killed the PTO and rolled it up to the house, praying I'd just picked up some rubber or rope that was causing the squeal. Nope. The seal was pushed out on the propeller shaft of the left gearbox and when I grabbed the shaft, it moves like there's no bearing in it. Great.
Video of it here: Titan 1810P Left Gearbox Failure - YouTube
So, I've lost a gearbox on a basically new cutter (Titan 1810P) and I'm hoping warranty will take care of it. It's not portable, but it's too dang new to have to tear into it. I have an email in to the company.
Anyway, my question... these 3 gearboxes are way quieter than my six-footers ONE gearbox, but all three of them were equally HOT. Almost too hot to hold your hand on. That's NOT like my 6-footers box, so it's making me wonder, did the factory NOT lube any of the boxes?
/ How Warm Should My Cutter's Gearboxes Get? #2
It is not unusual for gearboxes to be shipped dry. It is up to you the owner to make sure the gearboxes are full of the proscribed fluid before you place it into operation. In any case whether this was dealer prepped or not or filled at the factory or not, it is ALWAYS up to the owner as final inspector to make sure the gearbox has the proper fluid in it.
/ How Warm Should My Cutter's Gearboxes Get? #3
If the cutter was purported to be dealer prepped then you should be covered either by Titan for the seal failure or the dealer for ineptitude in checking or filling the boxes. If you bought the cutter at a discount Ag retailer like Rural King or Tractor Supply the responsibility for filling or checking the gearboxes will probably revert to you.
/ How Warm Should My Cutter's Gearboxes Get? #4
+1 on shipments with dry gearboxes. Most have a caution tag telling you to fill and what to use....most any implement/tool with a gearbox. I always check mine just to be sure and here in Tx. I use 140 not 90 that is usually recommended.
/ How Warm Should My Cutter's Gearboxes Get? #5
I have 5 different cutters that I use. All of them using different gear boxes, all of them with vastly different applications and HP ratings (from cutting trees with the Baumalight to light duty finish mowing). I'd say all of them range in the "little warm" to "very warm" category when running. None of the get so hot that I can't keep my hand on them. The hottest I'd say, it's like a car painted black sitting in hot sun. It's hot, but not "stove hot" (100's of degrees), more like "shower turned up too high" hot.
/ How Warm Should My Cutter's Gearboxes Get? #6
As a general rule of thumb, no pun intended, if you can hold your hand on it indefinitely, then the temperature is less than 140 degrees F. At or above 140 you won't be able to lay your hand on it for more than a second without feeling pain.
/ How Warm Should My Cutter's Gearboxes Get? #7
My Titan flail was shipped dry and had several visible warnings to fill the gearbox before use, but it sounds like maybe they handle the gearboxes on your cutter differently? Seems like if they advertise it as being factory filled then their warranty should take care of you. My experience with their customer service has been pretty positive so far. Just takes a couple of days usually for a reply.
EDIT: Oops, different Titan. Good luck on your issue anyways!
That's good to know. I'd say the boxes are right at 140 then, or just above that. The gearbox on my 6-footer never gets much warmer than ambient.
I agree that I should have double checked the lube in the boxes, but the manual was fairly explicit about being factory-lubed. (copied pic from manual)
The selling dealer called me back and doesn't think there will be a problem getting it replaced under warranty. I just wonder how long.
(This is Titan Implement in Tennessee.)
/ How Warm Should My Cutter's Gearboxes Get? #9
That is pretty plainly written. I find it odd that they use a "0" grease instead of the typical gear lube. People put cornhead grease "0" in gearboxes all the time when the seals leak, but normally new stuff has gear lube in them...
I'm still REALLY curious about checking the lube in the OTHER gearboxes when I get back out there.
Incidentally, I'm using a 55-horse tractor and the center gearbox is rated for 125 HP and the side gearboxes are rated at 100 HP. Can't say I was overtaxing it... and I wasn't mowing super heavy stuff.
Dealer now says a new gearbox is on the way, but I have to get the cutter to the shop. It's 1700-pounds and it's an hour away. Guess I'm borrowing a trailer.
/ How Warm Should My Cutter's Gearboxes Get? #12
Your numbers aren't accurate. As a general rule you can hold your hand on metal indefinitely if it's about 112[sup]o[/sup]F and at 140[sup]o[/sup]F five seconds is about the maximum length of time the average person can endure without sustaining irreversible burn damage. 120[sup]o[/sup]F is about the maximum safe temperature to touch.
/ How Warm Should My Cutter's Gearboxes Get? #14
I checked my Titan 10 footer when delivered and the gearboxes were filled. The dealership told me they check them before delivery but I checked anyway. Hope you get things worked out. Keep us updated on your progress.
/ How Warm Should My Cutter's Gearboxes Get? #15
if you are really curious, go get one of the infrared temp guns at h/f they are about 25 bucks with coupon well worth their value - we used one last year on a white 105 due to hydraulic issues and pump replacement - it was running around 175 degrees at the pump after replacement and we never noticed it being that hot even before the old pump failure, it was noisy, hydraulics would stop at times on start up, it was very strange, long story short, when old pump failed it sent debris thru the system, got metal in some pressure control valve that didnt come out with the rinse/flush at the shop. After taking it back to the dealer and replacing the valve then readjusting the pressures the pump is QUIET and runs around 145 to 155 depending on how hard its being used and outside temps.
/ How Warm Should My Cutter's Gearboxes Get? #17
I keep an I-R temp gun in each tractor, my pickup, and toolboxes. Always check wheel bearing temps when towing, hydraulics on tractor, and gearboxes. Cheap protection.
Type O grease is common in gearboxes and gear drives. At Gleaner combines, we designed a new gearbox for our corn head and tried everything possible to keep the boxes from leaking oil. We didn’t want to copy Deere even though we had tried their grease and it worked. Came down to production release and we had to follow Deere.
^ Great suggestions. Thanks.
Well... I'm not really happy with how long I've been waiting for Titan Implements to ship the new gearbox to my dealer. It's now been a month. :-(
/ How Warm Should My Cutter's Gearboxes Get? #20
Not good, you know about the "squeaky wheel syndrome" .
PORTA POTTY (A68842)
2008 FOREST RIVER CARDINAL 30RK 5TH WHEEL (A65643)
2008 FOREST RIVER...
2013 Ford F-150 Crew Cab Pickup Truck (A66736)
2013 Ford F-150...
2011 Chevrolet Express 2500 Cargo Van (A66736)
2011 Chevrolet...
2012 Gillig G27B102N4 Low Floor 32+54 Low Floor Passenger Bus (A66736)
2012 Gillig...
2014 MAGNUM FRAC MANIFOLD TRAILER (A67714)
2014 MAGNUM FRAC...
