lost tractor key
/ lost tractor key #21
My dealer confirmed that all L models share a single key and all Zero turn (ZD/ZG) mowers share a single key. Possibly true for other models as well.
/ lost tractor key #22
Most of the B-series (except the B26) use the same key.
/ lost tractor key #23
We had our key copied at a local locksmith. Was it more expensive than the dealer? Don't know because the closest dealer is 30 or so miles away.
/ lost tractor key #24
Our local dealer charged me $2.50 for a pair of replacements and key chains. Fortunately, we found the missing key in my shirt chest pocket (doh)!! :ashamed: I guess my only defense is that I was wearing 2 jackets since it was cold.
Before I had a chance to buy the replacements, I used my neighbor's key for her B2400 to start my L5740. I wouldn't have known to try someone else's key if a thread on TBN hadn't given me the idea that many keys are the same. :D
/ lost tractor key #25
My G2160 and BX2230 share the same key and so does some of the RTV 900s, the newer B series have a different key than the old Bs and the real old ones use another. most the Ls are the same. The RTV-1100 ignition and cab keys come from the M series and also the cab keys are the exact same one that is used on most RV compartment doors(CH751). Now I have noticed some of the upper end Kubota blank keys used on othe heavy equipment but the tumbler pin profile is different so that is why some can be cut and do not use just a stamped key. Indak keys are used on around half the lawn mowers with the rest usually being a Delta ignition switch. Arnold makes a universal key that fits most lawn mowers and older tractors such as a massey. Go to ebay and look at the key collections being sold to heavy equipment movers and mechanics.
Hope this makes it simple.
David Kb7uns
/ lost tractor key #26
your brother is not that forgetful he just kept the key so when you not at home he can still use it :D:D:D:D
/ lost tractor key #27
Since I have 8 of the same keys I can maybe loan one or two out. I got two keys with each Kubota so F2680E( about 3 years old), BX25, F2880 and RTV1140 (less than a year old) all use the same key. Small keys.
Don't remember for sure but think and almost positive my B's and L used bigger keys.
/ lost tractor key #28
The OP posted he ordered the keys he needs. Keys for most tractors and equipment can also be ordered on Ebay for anyone interested.
/ lost tractor key #29
All points already covered.
I had spare keys made at key maker.
Once at a relative's place I needed to use the FEL of a B-something Kubota to hoist an Axis deer for cleaning. Used my L5030 key...worked like a charm.
Nothing like the feeling of getting access to hydraulic lift power when it appeared that there would be none:thumbsup:
/ lost tractor key #30
I wanted a spare key when I had my B8200. It was at the shop getting the loader install. This was a local independent shop. The owner started my Kubota with a John Deere key. He indicated there is a lot of commonality of keys across model lines, AND manufacturers.
Based on his input, if you depend on your key as a security device, it aint.
I sold my B8200 before I got my NH TC40; I did not have a chance to see if the keys interchanged.
I think there is more than 3. My B21 and B2701 have different keys. My old M4700 (traded), M5040, and M9540 have different keys. Maybe there are a half dozen keys across the line in the past decade. But yes, they are common keys and that's standard for the industry.
I've ended up with a few extra keys from the dealer, free of charge.
Ken
/ lost tractor key
i can take my ford key an crank fords with it.heck you can take old ford car keys an crank newer ford cars an trucks.
/ lost tractor key #32
I tie a bright ribbon (usually red) about a foot long to my key ring so if I were to misplace it or drop it, it would be easy to find.
/ lost tractor key #35
To save that round trip get one of those magnetic key holders and stash a spare key under the hood or something.. Along with the key that paddle locks the steering wheel hard over to the right or left to make it harder for punks to take your tractor..
And I know, I know if they want to steal it they will do it no matter what.
/ lost tractor key #36
NOPE, I have 3 and each one takes a different key.
I think the are all the same such as for a B or BX
Agreed. I tried to joyride one of my friend's new B26 with my L4200 key once. Didn't work, dangit.
JayC
/ lost tractor key #37
Aren't all Kubota keys the same/interchangeable?
My dealer says they are all identical. When my BX was broken down and stuck in deep mud out in the field, they said they'd come pull it out after the mud dried and when they had an opportunity. I asked whether I needed to drop off the key. The dealer said no, all keys are the same. After reading the full thread, I see he must have meant all BX keys are the same.
/ lost tractor key #38
i know my neighbor's L4610 key fits my MX5000
I don't know how long Kubota has had their keys made like this... but I know the keys for one platform fit all tractors in that platform.
For example, the Keys for B fit all the Bs. The keys for the Ls fit all of the Ls. (Don't know if the Ls and Grand Ls are the same.) The keys for the Ms fit all of the Ms. (Don't know if the Bigger Ms are different from the smaller Ms.)
One thing I found out is the MXs are based on the L platform (Grand L?). The L keys fit the MXs.
I never have understood why equipment manufacturers do this. If one key fits everyone elses, why have a key? How much could it cost to have unique keys/locks/ignition switches? I think it is the same with the big CATs and others.
/ lost tractor key #39
One more thing. My L key turned upside down would work in a RTV. It was an 05-07 model RTV so they may have changed by now.
/ lost tractor key #40
Never lost a key.
1) Use a rope lanuard
2) use a small D shaped spring ring (rope) hook for each key
3) attached a quarter size standard key ring to each key
4) you'll have the lanuard, with each key on a key ring and it's own D ring.
I just take the entire rope thing back to my shop, hang it on a hook, pick the key I need (take a key from that D ring). When I'm done for the day, it's quick to see if I'm missing any keys...just look for the D ring without a key.
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
Rhino 1540 Blade (A63116)
Rhino 1540 Blade...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
2006 Mack CV713 Flatbed Truck (A62679)
2006 Mack CV713...
2019 HINO 268 4X2 26FT NON CDL BOX TRUCK (A59911)
2019 HINO 268 4X2...
2017 Infiniti QX50 SUV (A61574)
2017 Infiniti QX50...
