Loose pulley on YM1510d
/ Loose pulley on YM1510d #1
yellowdog5
Yanmar
I have had this tractor a long time but never done anything but routine maintenance, the pulley behind the fan wobbles a little, can I tighten it or do I need to replace something?
/ Loose pulley on YM1510d #2
Can try tightening it; if that doesn’t fix it, then probably just replace it. Assumes the attachment points aren’t rusted through, of course.
/ Loose pulley on YM1510d #3
If it's been wobbling for a long time, it's most likely wallowed out on the backside and will need replaced.
Thanks everyone I'll do some checking and see if I can figure it out.
Where can I find a water pump?
/ Loose pulley on YM1510d #8
/ Loose pulley on YM1510d #9
Winston, what a great price. I'm having the hardest time even getting close with the known Yanmar aftermarket parts distributors.
/ Loose pulley on YM1510d #11
How about just replacing the bearing & seal ? Although I don't blame you for wanting a complete new part.
Do these pumps fit both diesel and gas motors? (mine is 1510d). Is the more expensive one worth the extra cost? I don't want to have to replace it again.
/ Loose pulley on YM1510d #13
These little Yanmars don't have gasoline engines. I cannot answer your question whether the expensive one is worth the difference. Some say you get what you pay for, maybe, maybe not. I'm sure you will get more comments on your question.
/ Loose pulley on YM1510d #14
Better pump, New pully Mounting studs and a Water pump Gasket. The higher price. Also noted. My 2 cents
Price Match Request​
Found a better deal? Take advantage of our best price guarantee! Fill out our form and we'll match the part price and give you a 10% bonus discount for the effort!
/ Loose pulley on YM1510d #15
The Amazon pump also comes with studs and gasket.
/ Loose pulley on YM1510d #16
They're match the VN el cheapo part price!! Plus 10% ;)
I ordered the amazon one, part number is the same as the most expensive one. Thanks everyone for your input :)
I am finally getting around to replacing this water pump. When I removed the old pump, there is a block behind it that pulled loose just a little. Do I need a gasket for that also? If so what gasket do I get? The seam in the picture is where it is loose, the pump mounts just below the hose clamp with long bolts going through the block.
/ Loose pulley on YM1510d #20
You need to be careful with the Chineseum parts as they don't always fit correctly. I know someone that bought one for their Kubota (not me) and the impeller was sticking out too far and ate into the timing cover under the impeller and that was an expensive ordeal. if you get one, just don't bolt it up but makes sure it fits correctly before buttoning it up and filling it with coolant. There is not much clearance between the impeller and the timing cover. The Chinese are good at copying stuff but they don't always get the clearances correct. That retailer sells a lot of Chineseum after market parts so beware.
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A59905)
2013 KENWORTH T680...
2017 Skytrak 10054 10,000lb 4x4 Rough Terrain Telehandler (A59228)
2017 Skytrak 10054...
17307 (A55853)
17307 (A55853)
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60430)
KNOW BEFORE YOU...
