Looking to buy Yanmar tractor
   / Looking to buy Yanmar tractor
tractor plans are on the back burner for now...
Trailerability is an issue, but not a huge one. We used to tow a 8k lb boat around a decent bit, so we can do it.
I'm going to spend some time messing with the little bit of cleared area we have for now and over the near-term, do some planning on what I want done to the property before going "all in," so to say.
I do appreciate y'alls help. Still liking the Yanmars, too. May look into an upper-20's HP machine now. I'm just not exactly sure how much I will be using this thing. I do know, once I have one, I'll be "making" work...
   / Looking to buy Yanmar tractor #62
Just remember a 20 hp machine and a 29 hp machine will do the same work basically as well as a 35hp machine, its just how long it takes to do the work.
Good choice. If you were around my area id say come drive and help disk some of my fields with me so you know how the 2000 handles an actual implement, something you cant get a grasp of just driving one around.
   / Looking to buy Yanmar tractor #63
This depends on the type of work, mowing and light scraping I would agree. But there are limitations to what certain HP can do. 20hp machine will not pull up large tree roots when plowing regardless of the amount of time you spend on it, a 100 hp machine will.
   / Looking to buy Yanmar tractor #64
Correct, but he said he had a track hoe to grub the stumps first. I toatlly agree with what you saying though smoody. There is a difference between a 65hp tractor and a 8ft boxblade and my 24hp tractor and a 4 ft boxblade!
What if you hold your mouth just right?
your daddy never said "you must not be holding your mouth right" as you struggle with something?
   / Looking to buy Yanmar tractor #68
nope never heard that one! I figured out what you meant though.
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
John Deere 5105M (A53317)
John Deere 5105M...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
GENIE S-60 MANLIFT (A58214)
GENIE S-60 MANLIFT...
1974 Ford F600 Grain Truck (A56436)
1974 Ford F600...
