Looking for a log splitter
/ Looking for a log splitter #61
Hello. Im thinking of buying a log splitter.. as Ive got about 50 trees that have been felled and logged, and I dont fancy doing it all with an axe.. logs range from 10cm- 30cm diameter.. any recommendations? oh and I dont want to spend a fortune on one..
I was contemplating 3PH splitter until I learned the hydraulic flow rate of my tractor was so low splitter operation would be slow.... While procrastinating a used 22 ton came up for $200 with blown motor, new motor and hoses put me in good operation a lot less than 3PH would have cost me.... Now with stand alone splitter my tractor is free to move big stuff onto splitter when its to big/heavy for this old man to handle....
/ Looking for a log splitter #62
I have the 27 ton Champion log splitter and really like it. I haven't found anything it will not split and I have put some massive splits on that machine. It always starts first or second pull no matter how cold it is. I would buy it again in a heartbeat.
/ Looking for a log splitter #63
I have the same splitter. I haven't had mine for very long, but it's surprising how easily it starts. I turn the fuel off after every use and let it run out, but it only takes 2-3 pulls to start it again, the next time I use it. It's really easy to pull the starter cord too.
/ Looking for a log splitter #64
I don't split at all any more. I cut the fuel logs in to wafers/ rounds that will fit the stove. 4 inch, 6 inch, or so thick. Too wide to fit, and I hit those with the maul to break them. Doing it this way for five years. Its a different style. But for me, Doug Fir mostly, it saves time and stacks better. Its also easier to stack and bring in the house. I found that my wood stove runs hot all the time anyway. So just layering them the right way in the stove gives all the air needed for a clean burn. The chips get reused as starters.
40' 6 Door Shipping Container (A68183)
40' 6 Door...
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
2020 Nissan Murano SUV (A66738)
2020 Nissan Murano...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
ZINGER BY CROSSROADS BUMPER PULL CAMPER (A67714)
ZINGER BY...
2012 Gillig G27B102N4 Low Floor 32+54 Low Floor Passenger Bus (A66736)
2012 Gillig...
