Looking for a log splitter
/ Looking for a log splitter #61
Hello. Im thinking of buying a log splitter.. as Ive got about 50 trees that have been felled and logged, and I dont fancy doing it all with an axe.. logs range from 10cm- 30cm diameter.. any recommendations? oh and I dont want to spend a fortune on one..
I was contemplating 3PH splitter until I learned the hydraulic flow rate of my tractor was so low splitter operation would be slow.... While procrastinating a used 22 ton came up for $200 with blown motor, new motor and hoses put me in good operation a lot less than 3PH would have cost me.... Now with stand alone splitter my tractor is free to move big stuff onto splitter when its to big/heavy for this old man to handle....
/ Looking for a log splitter #62
I have the 27 ton Champion log splitter and really like it. I haven't found anything it will not split and I have put some massive splits on that machine. It always starts first or second pull no matter how cold it is. I would buy it again in a heartbeat.
/ Looking for a log splitter #63
I have the same splitter. I haven't had mine for very long, but it's surprising how easily it starts. I turn the fuel off after every use and let it run out, but it only takes 2-3 pulls to start it again, the next time I use it. It's really easy to pull the starter cord too.
/ Looking for a log splitter #64
I don't split at all any more. I cut the fuel logs in to wafers/ rounds that will fit the stove. 4 inch, 6 inch, or so thick. Too wide to fit, and I hit those with the maul to break them. Doing it this way for five years. Its a different style. But for me, Doug Fir mostly, it saves time and stacks better. Its also easier to stack and bring in the house. I found that my wood stove runs hot all the time anyway. So just layering them the right way in the stove gives all the air needed for a clean burn. The chips get reused as starters.
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
2022 EZ-GO ELITE...
2008 SUBARU LEGACY 4 DOOR SEDAN (A65054)
2008 SUBARU LEGACY...
2015 BMW X1 SUV (A64557)
2015 BMW X1 SUV...
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
1997 Jeep Wrangler 4x4 Off-Road SUV (A64194)
1997 Jeep Wrangler...
