Looking for a good compact tractor
/ Looking for a good compact tractor #61
"Loading" the tractor's rear tires with liquid will increase traction in a cost effective way.
Adding wheel weights will also increase traction, though iron weights are much more costly.
MORE ON WHEEL/TIRE BALLAST:
Consider routinely carrying around a Three Point Hitch implement as FEL counterbalance and additional wheel ballast if you need yet more traction. A considerable amount of the implement weight is transferred to the tractor wheels, both front and rear, through the Three Point Hitch.
Before your next tractor purchase consider this: Within subcompact and compact tractor categories, a significant tractor capability increase requires a bare tractor weight increase of 50%. It takes a 100% increase in bare tractor weight to elicit MY-OH-MY!
The problem with fluid in the tires is when a tire gos flat.....and they do go flat from time to time. Food for thought
/ Looking for a good compact tractor #62
I'm looking for a compact tractor for 11 acres. 5 of those acres have a lot of dead trees we are looking to remove. We have goats and are looking to get more animals, and will need a tractor that can handle those. We also would like to be able to lift and pull a good amount. Any recommendations?
Well Reagen - when you return, enjoy the dialogue and discussion on this thread! There are some good nuggets here - it's really how and which of those nuggets resonate best with your situation and goals.
BTW, "We have goats and are looking to get more animals, and will need a tractor that can handle those" I don't a tractor that can handle goats or any animal!
/ Looking for a good compact tractor #63
I guarantee, if you hit an unseen obstacle in the woods, even at low speed, your foot would jerk away from the clutch pedal. And if the tractor really did start to do a wheelie, at 1 mph with a 50" tire, it would take about 2s to reach 90 degrees, the point of no return. My bet is you would have trouble keeping your foot on the clutch then, too. Of course, you could put anti-rollback legs on the tractor, as they do in tractor pull events. You could also pull with a scraper blade. Any large implement would stop a wheelie rollover, but not a side rollover. And I still had a close call with a sapling that popped up when it hit the front axle and ran into my chest. It nearly broke my ribs, which hurt for a week. And this was with an HST, where all I had to do was stop pressing the pedal. I am not trying to say which transmission is "better". I am trying to point out situations where there is an actual safety difference. And any system which requires more operator skill to avoid an accident is intrinsically more dangerous. I think that should be obvious. And the original poster indicated a variety os uses for the tractor. Woods use was one of them. That is probably the most dangerous activity a tractor can be used for,
I guarantee that if your control is so bad that you cannot stop your tractor (your own words by the way) then HST will not make a bit of difference. Hitting an obstacle with HST could cause you to increase pressure on the pedal and make things worse. Your imagination that makes a clutch foot wildly flail about but magically, your right foot is under control has more to do with your ability to spin a yarn than how one system works versus the other. BTW, many shuttle shift tractors do not require the clutch to change directions. Of course, if the narrative is that my hands also fly off the steering wheel, that would be hard. It is perfectly OK to admit that you prefer HST. Don't make false statements about it being inherently safer than a shuttle shift. I don't want someone else to get injured or die because they have a false belief that the HST will prevent accidents. All tractors are only as safe as the operator is being at the time they are being operated.
/ Looking for a good compact tractor #64
As Torvy said, go to school on whatever you decide. Spend whatever amount of time you need to understand each and every aspect of the tractor not only for your own safety but for your family as well. Personaly I like the powershuttle but I wouldn't say it's any safer than the other choices. Good luck and have fun
/ Looking for a good compact tractor #65
I've been in the woods since the late 50s with Farmall Hs and Case SCs. (Hint: don't turn sharp to the right). I also have owned a HST for the past several years.
I agree 100 per cent with Hermio. While log skidding, to get to the clutch pedal in time to stop a rear "flip over" is going to be very hard, even when traveling slow. Someone previously mentioned .5 seconds. I doubt it is even that.
What will be harder yet is holding the clutch down when the front end crashes back to earth. Chances are you will be slightly (or majorly) displaced from your normal seated position. Try KEEPING the clutch pedal down thru all this.
In contrast, as soon as your start a flip on a HST, you remove your foot (just as fast, or faster than a clutch) from the HST pedal. The tractor stops, crashes to earth, and operator can be flipped off the back, out of position or even on the ground, the tractor doesnt move again until the HST pedal is depressed. Which will be some minutes while the operator gets cleaned up and changes his underwear.
/ Looking for a good compact tractor #66
Interesting I never really thought how a hydro could be safer in this regard but it does make sense.
/ Looking for a good compact tractor #67
It also illustrates how important it is to use the drawbar instead of 3PH for pulling something.
/ Looking for a good compact tractor #68
You are missing the point. Kubota is historically known for lighter machines in a given “class” if you look at dimensions of the machines. Thats what I am saying.
I look at it a little differently. All tractor manufacturers offer lighter and heavier tractors for different markets, and offer different power levels within a tractor frame size, and offer different frame sizes for a reason.
If a given Kubota, say, at a given power level, is lighter than a Mahindra, for example, then the two may not be really comparable, and perhaps you should be comparing the next frame sized up Kubota.
The point being that most manufacturers offer different weight tractors at the power level you want, so choose the model that fits your both weight and power level.
Comparing a Kubota B with a Kioti isn’t right. Should be using something like an L or Grand L ( I don’t know my Kubota models, but you get my drift).
It’s senseless to compare a Smart car and a BMW 5 series, but , then again, Mercedes offers more than the Smart.
/ Looking for a good compact tractor #69
You arent considering dimensions. L, W, H, wheelbase also matter. There are always reasons not to move up a frame size just to get the same weight. This affects storage, interaction with implements, stability, and accessibility.
We usually compare tractors by their dimensions…then look at weight. I would not consider a machine that is the same weight but 2 feet longer than another to be comparable.
/ Looking for a good compact tractor #70
A Mahindra 1626 would be perfect for your plans. You'll need the rear tires filled no matter what you buy.
Hydro or shuttle options available. I have the shuttle but that's my preference.
I use mine for a business. From burying horses to bush hogging,It's been an amazing machine. If something happened to it, I'd buy the exact same thing again.
/ Looking for a good compact tractor #72
I would buy cast iron weights or build a ballast box long before I would concider any liquid weight.
Liquid weight is always there. Much better than weights. Been there, done that. Plus good luck finding weights and getting them shipped. Washer fluid is cheap and available everywhere.
Ballast box is great until you have to take it off for another Implement. I bush hog on steep hills, the fluid in the tires is night and day when it comes to stability on hills.
/ Looking for a good compact tractor #73
Well I live in an agricultural area and weights are not hard to find. Any dealer has them. What do you do with washer fluid in your tires when you don't need it. Your stuck with it and I like a nice light tractor for mowing my lawn and other jobs.
I have 600 lbs on a 3 point hitch bracket. If I don't need weight I remove it. It doesn't work that way with liquid. I use a quick attach with a hydraulic top link. Exchanging implements is quick and easy.
Many times I have lifted the bush hog just enough to pull the rear tire down so that it's on the ground again. If I'm in a really steep situation it's time to install my duals. More weight...Never.
/ Looking for a good compact tractor #74
I never don't need it. It has never been a problem. I till a lot, still never an issue.
Not once have I ever wished I hadn't filled my tires.
I don't mow lawns with my tractor though. Bush hogging only.
I'm in East Tennessee. At the base of the Smoky Mountains. If there are wheel weights around here, they a hiding them well for some reason. Never see them around here. Tried to find them when I first got the tractor. Honestly, I'm glad I didn't.
/ Looking for a good compact tractor #75
Let's face it there are situations where filled tires are, and are not desirable.
/ Looking for a good compact tractor #76
I imagine one advantage of loaded tires is that they probably lower the center of gravity.
Not sure how full “full” is, though.
I had mine done as part of the deal. I don’t mow lawns, though.
/ Looking for a good compact tractor #77
Fill can vary but is generally either about 40% or 75%. There are several ways to tell how full a filled tire is. The easiest way is to simply look at a filled tire on a warm, humid late winter or early spring day after it has been cold for a while, you will see condensation on the tire where the fluid is and no condensation above the fluid level. The next easiest is to tap on the tire gently and listen for the dull thud you hear lower down on the tire to turn into a hollow thump. Where this changes is your fluid level. I did the "tap" method to find out mine are about 75% full, just above the top of the rim. Other ways include removing the fluid and measuring it, and weighing the filled, mounted tire, subtracting the published weight of the empty tire and rim, and then converting the resulting weight into gallons based on fill weight/gallon, and computing the percentage fill based on the published fill capacity of the tire.
If you know what your fill is, that may tell as well. If you have tubeless tires with calcium chloride fill, they must be filled so that the rim is completely under fluid, which is generally at that 75% level. If the rim in a calcium chloride filled tire sees air, it will rust very quickly.
/ Looking for a good compact tractor #79
I'm for sure in a minority but I don't agree that tractor weight is the most important criteria at all. You can always make a light tractor heaver but you cannot make a heavy tractor lighter. For mowing my lawn I want my tractor as light as possible. If I need extra weight for stability or traction I can always pick up my rear three point hitch weights. If I need more weight up front I have two different sets of front weights depending on the job. The two most important considerations are: How well the dealer takes care of you and is able to supply parts, and how comfortable and intuitive the tractor is to operate. For example I will never buy a treadle pedal HST tractor. Others find them comfortable but I don't. Also very high on the list is reliability.
I disagree on the weight but I would never mow my lawn with my tractor but that's just me.
I agree with you 200% on those stupid treadle peddles. I'll never buy one either.
/ Looking for a good compact tractor #80
Weight is your friend and I also believe that the best way to get the most from added weight is from filling the tires.
40ft High Cube Shipping Container (A65583)
40ft High Cube...
2018 John Deere 3025E (A64126)
2018 John Deere...
2017 Genie GTH-636 (A62177)
2017 Genie GTH-636...
1995 John Deere 7400 (A60462)
1995 John Deere...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
