Looking at pull type snowblowers
/ Looking at pull type snowblowers #102
That loader operator has one monotonous job..
/ Looking at pull type snowblowers #103
I have a lucknow 78" Pull type on my Compact and it works great. Super heavy duty and it weighs a lot. It hangs way off the back of the 3 pt arms. I would stay away from the small pull types (like 5 footers) because the arms are super short to keep the weight close to the tractor, making the driveshaft angles pretty extreme.
The wider the better to get close to buildings.
They are for routine snow removal (daily in my area) Not for opening up roads in the spring.
Driving over the snow is a non issue. and a bucket full of wet heavy snow helps with front tire traction.
Remeber if it ever got that deep you still have the loader on the front to pick away at it, and a lot of weight on the back.
I have a front mount that never goes on anymore due to loosing the loader all winter, and the amount of time it takes to put on.
/ Looking at pull type snowblowers #104
Bump of an older thread, but I finally bought a Meteor 68" rear pull. Getting 5"-10" of snow is common here - seldom do we get over 15", so I'm not worried about driving through it. For my needs it is way faster and easier to use than my old 3pt Meteor. Here's my first use.
/ Looking at pull type snowblowers #105
Nice video, Airbiscuit. Your conditions, with moderate snows and limited drifting seem ideal for a pull-type blower. I have similar conditions here. I understand why some people cannot use pull-types because of frequent deep snowfalls and/or heavy drifting but for some of us inverted blowers are the best solution.
/ Looking at pull type snowblowers #106
You also don't have to worry about hitting anything with the spinning auger backing up. I don't suggest you get in there to mess with the PTO when it's running though.
I would love to play with one.
2006 International 9400 Semi (A66285)
2006 International...
Tri Axle Rolloff Truck (A64194)
Tri Axle Rolloff...
2000 STERLING T/A DAY CAB ROAD TRACTOR (A64278)
2000 STERLING T/A...
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
2025 Good Luck Go Cart (A64557)
2025 Good Luck Go...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
