Looking at pull type snowblowers
/ Looking at pull type snowblowers #41
Be prepared for sticker shock when you ask for a price for that unit buying it in the United States.
If you still have your Kawasaki mule with the winch you can mount a motorized Bercomac 2 stage snow blower from Jims Repair on it for much less money than that Pronovost inverted 2 stage snow thrower but more money than a Riest Series 1000 with a 6 foot cut and hydraulic chute rotation and hydraulic spout control. The only way you will save a lot of money with the purchase of a Pronovost 72-IV inverted snow thrower is if you purchase it in Ontario and you bring it across the border.
A front mount blower with the 3 point power pack is expensive - $10-15K. Not worth it to me. Our worst lake effect snows might be 24" over a couple days, but most of the time it's around 6" or so. Plus is southern Michigan we usually get warm, melting weather in between storms. It would be different if I was in the UP. I plowed for several years with a Kawasaki Mule and did just fine. I've never owned a blower and would like to try one I think. My local Kubota dealer can get the Meteor for $3,995. There are also dealers in the area that sell Pronovost and Erskine pull types. Any idea which is the better unit?
Which meteor is that? Back up or pull and what width?
/ Looking at pull type snowblowers #43
If you go to the Beaver Valley Supply home page they list all their snow blower prices and prices for the options available for these snow blowers.
/ Looking at pull type snowblowers #46
MK Kartin Meteor has a 5 blade 27" Fan
Erskine has a 4 Blade 24" Fan
I have looked at Beaver Valley. Really just wondering if anything out there for comparable money that may be better.
/ Looking at pull type snowblowers #49
The fan is what does all the work. The rest is mostly fluff .... Bigger/deeper/more fan blades usually does more work than smaller/shallower/less blades... The blades are the shovels, more and bigger shovels is a good thing... :)
/ Looking at pull type snowblowers #50
In selecting a blower driven off the rear pto, most buyers overlook the end result of pto joint angles. This is why fan diameter is very important as 1/2 the diameter is what you would like to have match the height of your pto shaft so that joint angles, when working, are as close to zero degrees as possible.
This chart shows how quickly pto joint life can be reduced.
20 hours with 25 degrees and 450 hours with 5 degrees.
Dave M7040
/ Looking at pull type snowblowers #51
Dave M7040
that's for a standard PTO shaft, what about wide angle CV joints?. https://www.tractorbynet.com/forums/build-yourself/61915-source-pto-shafts-wide-angle.html
/ Looking at pull type snowblowers #52
Dave M7040
My old Lorenz manual said a 5deg (1"/ft) will cut life by 40% and a 10deg (2"/ft) will cut life by 70%. It is sure something to be aware of.
/ Looking at pull type snowblowers #54
They dont help a lot I expect. They add a lot of length to a PTO shaft & blowers dont have long shafts to start with.
if you completely read the link, they are used on front wheel drive cars, and trucks, and last many thousands of miles, at a much higher HP..
/ Looking at pull type snowblowers #55
Yes you can buy ag pto shafts with CV joints but at greater expense. They are usually used with 1,000 rpm pto's on large tractors which require a high degree of lateral deflection because they are pulling implements attached to the draw-bar and not to lower arms of the 3 pt.. Not that it makes much difference but with an implement fastened to the 3 pt hitch there is minimal lateral movement and any deflection vertically comes from initial setup and then raising implement. Also the Ag CV pto's are much longer than one needed for a snow blower.
The big factor in any joint, Cardan or CV is the transmission of torque not horse power. What can be deduced from this is that the front axle drives on cars using CV joints are working at much higher speeds than 540 rpm hence their ability to transfer much higher horse power levels across the joint.
My only reason for my initial post was to suggest to buyers of blowers to not be totally focused upon fan diameter.
Dave M7040
/ Looking at pull type snowblowers #56
Rzeppa Univeral joints are very expensive and require a huge amount of greasing at every shift to fill the cage full of grease and they come in five pieces/plates that have a spring cage in them that has to be assembled onlyone way and they would require a carrier bearing to support the short PTO shaft stub with the female end.
/ Looking at pull type snowblowers #57
I never said they couldn't transmit the power. I said they took up a lot of space. If you have a short shaft at moderate angles then make it even shorter due to longer joints the angles they run at will get a lot sharper. And as others have already pointed out, the sharper the angles you run them at the exponentially shorter their lifespan.
/ Looking at pull type snowblowers #58
Interesting conversation, but has any TBN member wore out a PTO universal joint? They don't cost all that much to replace.
/ Looking at pull type snowblowers #59
it had to have happened, but, you'd not want to be out in the freezing cold, with a blizzard going on, removing a PTO shaft, and looking for a place that is open at that time, so you can do your snow plowing!..
/ Looking at pull type snowblowers #60
I grew up on a farm, and I only remember changing one on a baler. On sharp turns, you could hear the knuckles knock. Yet, only changed one PTO joint on all our equipment. Not sure this is a very big problem.
2002 International School Bus (A64194)
2002 International...
3147 (A63117)
3147 (A63117)
Skid Steer Rock Digger (A65640)
Skid Steer Rock...
(4) Texas Built Stand Alone Livestock Panels (A66408)
(4) Texas Built...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
Michelin Mach X BIB 710/70R42 Tires (A65640)
Michelin Mach X...
