Looking at getting a UTV.....
/ Looking at getting a UTV..... #21
I just GOOGLED "electric utility vehicle". There are some cool 4WD ATV's. Check them out. And they have tax credits with them!! Dave
/ Looking at getting a UTV..... #23
Looks like some of those are in direct response to the availability of the tax rebates.
Sure does. American capitalism at its best. If I was smart, I would have thought of getting into that market.
There are some testimonials on hunting with the electric UTV on one web site.
Only problem I saw was there is no cab heater. I guess a guy could haul a propane heater with him. Dave
/ Looking at getting a UTV..... #24
2 Fast 2, I actually brought it to the deal this week to have them look at it. They said they was no problem with it and it should get better after break in (only has 10 Hr's) like you had mentioned. I was talking to my buddy and we are going to get together to compare them, his has 200 hr's on it. It seeems its biggest problem is on steep hills. How is the diesel overall been?
I think the old adage "it will get better with break in" is BS. The power you have will not change significantly unless they find something wrong. People tell me my diesel truck will get better as the engine gets broke in is just a way of saying "Sorry, it is what it is."
/ Looking at getting a UTV..... #25
I agree for the most part -- it's another way of saying...
"You'll get used to it..."
That said, things like fuel economy will improve slightly after break-in, as the friction is reduced by wear. Doubt you'd ever notice an increase in power, though. In fact, you're usually cautioned not to run one at "full power" -- whatever RPM that may be -- until after break-in...
/ Looking at getting a UTV..... #26
Like the OP, I had ridden Sport ATVs and Sport Utility ATVs. I bought a used Rhino Sport 660 a few months ago. The Sport model has external reservoir, fully adjustable shocks on all four corners. Mine is an '07 and had 103 miles on it and was spotlessly new, paid $7000.
I was looking for a similar machine as he described. I especially wanted compact size. I use it to haul chain saws, fencing materials, coolers etc. I also drive it hard and fast on timber trails, Jeep trails, Hare Scramble trails, etc. I added ITP 27" 589s and 1.5" wheel spacers. It'll 4 wheel very well. It'll jump very well. Will not quite corner with a Sport Utility ATV but close. My biggest disappointment is 42 mph top speed. Next modification will be a new clutch and rev limiter which will get the speed up around 60 mph.
If buying a used Rhino again I would suggest getting an '08 or newer to get the 700 EFI upgrade.
EDIT: Forgot to say, for Sport riding, the best feature of the Rhino is fully selectable 4wd.
2wd, both rear wheels pulling together. Used for normal operation. Rear axle is always locked and always engaged.
4wd, both rears pulling and front axle engaged but unlocked. Great for fast 4wd operation. Still steers easily, will power slide thru corners and get you thru most situations.
4wd locked, both rears pulling and front axle engaged and locked. All four wheels pulling together. Great for off camber situations where one front tire is airborne. Down side is hard to steer.
Brands without front differential always steer heavy when in 4wd. Rhino gives you a choice.
/ Looking at getting a UTV..... #27
I have had many 4 wheelers w last being Polaris Sportsman. Awesome 4 wheeler with 4 wheel drive system the best. The sportsman backs up hills others cant drive forward up! My side by is a John Deere xuv. Awesome 4 wheel drive system also. It is no hotrod (32 mph flat ground). But it will haul a full pallet, much more work oriented than any other. Also smooth riding independent suspension. I do like the JD xuvs. Mine is limited w the fmf exaust.
/ Looking at getting a UTV..... #28
I have just purchased a Bad Boy LSV (low speed vehicle). You can drive it on the road and off of course. It comes with a tax credit of about $5700 and the vehicle sells for about $10,400. I got mine for $9,400, sooo subtract $5,700 and you get a nice vehicle for $3,700.
Check it out at badboymowers.com. It has two speed axle, 4x4, pushbutton dump bed, alum. wheels, brush guard, roll cage with a roof, all legal for the streets with 35mph speed limits. You can roll right up on turkey while creeping along logging roads.
/ Looking at getting a UTV..... #29
From what I have read some models will fit in the back of a 6 foot pickup bed. That would be a plus as well.
Is there a model that will do it all?
I don't think you will find any UTV that will fit into a 6' bed. Heck! I don't think you'll find any that will fit into a 8' bed either. That's ATV sized. Our Kaw Mule likes an 11'+ trailer because it's a tad over 10' long. It also has a wheelbase wider than 4' (a bit over 57" wide). If you can find one that fits into the bed, it's not really a UTV in my opinion.
/ Looking at getting a UTV..... #30
Actually the Polaris Sportsman has a trouglesome 4wd system. It also does not have a front differential so always steers heavy when in 4wd. Polaris runs the front driveline engaged at all times. To get 2wd they disconnect at each front wheel using electromagnetic devices. Creates more opportunity for failure because of maintaining two devices.
Worst problem with them is they will engage themselves when doing high speed rear wheel spin. Makes a terrible banging sound, yanks the bars out of your hands and tries really, really hard to tear itself up and throw you off. Also will sometimes disengage when changing direction quickly. Not pretty. :mad:
I don't have personal experience with Polaris Ranger or RZR so can't comment on what system they use, just assume it's the same as the Sportsman. :(
/ Looking at getting a UTV..... #31
I just recently bought a 620 gator XUV. I am thinking i should have bought the diesel or looked at he Ranger. It seems to be very well made and has a nice big bed. It has no preformance for recreational use and is very poor on climbing steep hills. I didn't do much research because my freind has one and he loves it and says how powerful it is. I guess everyones idea of power is different. I was very disapointed when it barely climbed the will I was on in low range with no load. It is a 2009 so if want to get something else I am going to loose a ton of money. I have heard the 2010 gas XUV will have around 50 HP :D. I should have waited. :(
we looked at kubota 2660 tractor and the kubota "R" car, we agreed that the Gator XUV was the best choice for our horse farm.
/ Looking at getting a UTV..... #32
I have a 610 Mule that is 47" wide, will fit between the wheel wells of a full size truck. Would probably fit in a 6' bed with talgate down as it can be hauled on an 8' trailer. It is not the fastest or sportiest model in the field, but it starts right up, runs forever on a tank of fuel & has done everything I have asked of it --including hauling fuel & seed between fields & pulling trailer loads of firewood out of the timber. My wife picked this out as she could not get on an atv with her bad knees. We looked at Rangers, Rhinos, Gators, 3010 Mules & the 610's. She thought the 610 was easier to get in & out of & could hold her & two grandkids which others with bucket seats couldn't do. If I want to go flying through the fields & jump some terraces I just get on one of the atv's. Just have to decide on what you want to do with one as the OP stated an interest in a smaller unit.
/ Looking at getting a UTV..... #33
one thing to look at is if you don't like it after you get it then what I always look at resale Yamaha rhinos resale is excellent and not a bad product just remember stop before you change directions it is costly price $13000 basic Polaris you the dealer wont even take them back on a trade down here I have heard bad things about Kawasaki terex.. the nabour has one not good he said ??? cat not built strong enough a arms rip off ...... there all the same to some just some things diff but the harder you bet them the shorter the life of the machine I hope this advice helps Brian
/ Looking at getting a UTV..... #34
I have to disagree with you. I have run my neighbors 2up Sportsman through the woods and pastures along with snow plowing in all modes. It is a fantastic ATV..It's big and heavy, but felt none of the things you are referring to. Handles nice and rides like a Cadillac. Runs up hill climbs like nothing.
/ Looking at getting a UTV..... #35
you dont know what you are talking about. Polaris makes the best 4 wheel drive on the market in the sportsmans. i have owned them for years! we are talkin utvs. Polaris is good. I like JD xuvs. Decent ground speed, excellent suspension, and will haul the house!
/ Looking at getting a UTV..... #36
I'm sorry guys but I do know what I'm talking about. I've owned three Polaris, two Kawasaki, three Yamaha. The last Yamaha being a side by side, all others being ATVs.
The Polaris is the most troublesome 4wd system and is the hardest to guide/steer. The Sportsman is the cushiest ride and the most stable in off camber situations but takes arm strength to ride. It tries to drive you rather than you driving it.
I'm not picking on them, just pointing out differences. These differences probably bleed over into the side by side models as well.
I ride frequently with a friend that has an early model Polaris RZR. The 4wd system has broken three times, twice I witnessed the breakage which was not under abuse.
Everybody rides their machines differently. I ride hard and fast. I took it by the OP's description of his history that he might also. With that considered, I would avoid a Polaris.
If the intent is to put-put around and occassionally throw something in the bed, buy whatever model appeals to you, they'll all hold up under those conditions.
Merry Christmas!!! :)
/ Looking at getting a UTV..... #37
My mechanic loves Polaris. He stated they are the best customers because of frequent repair and alot of one only parts applications. Personally I wouldn't buy one because I don't have the cash to support problems down the road.
Alot of people must like them because of so many in service. My next new purchase will definately be Honda. Not because I have several Hondas..... the lack of costly maintenance steers me in this direction. My 2 cents on the issue.
/ Looking at getting a UTV..... #38
I have had Yamahas, Suzukis, and Kawasakis cant say any of them were problematic. I bought a Polaris Ranger XP 3 years ago. At the time I had 4 atvs. Over the the course of the first year I ended up getting rid of all of the atvs, just never used them.
I have had the Ranger in places I would never venture with my quads, climbed hills where my passengers jumped out before I started up, and now I currently plow a 900 foot driveway with it and have a buyers spreader hanging off the back that weighs 350# loaded. Oh, and i take the kids to the bus stop daily, zip back and forth between my shop and the house constantly. Never one ounce of trouble. 145 hours and counting (45 in the last 4 months). Never even a hicup.
The 4WD system is incredible and these machines are basically bulletproof in my experience.
I thought about a new one with powersteering, but now am going to install an aftermarket (unisteer) system. I am in the market for a Quad again. I can't take the ranger from my property (wife loves it too) when I go hunting and I have so much "work" stuff on it now that i dont want to damage.
/ Looking at getting a UTV..... #39
We bought out Polaris ranger about 7 months ago. Its been great ever since. It only has 25 miles on it, and maybe60 hours.
Handles great, rides great, and the 4wd system is great.
We bought it because our neighbor has had 2 and never had an issue other then a few broken axles (he really pushes his luck with things.)
We use to have a 6x4 like a gator and it jsut didnt turn.
A good friend of mine has a Gator XUV or whatever it is called, and after riding and driving the ranger, he's put his for sale and picked up a 10 Crew.
/ Looking at getting a UTV..... #40
Thanks to Keith and Miles to Empty for making my point. If you are after occasional, light use, go Polaris, you might get by with only a few broken axles as mentioned by MTE.
I consider 145 hrs in three years and/or 25 miles in seven months light use. :)
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
2014 Chevrolet Equinox AWD SUV (A64557)
2014 Chevrolet...
2026 MACK GRANITE GR64F DUMP TRUCK (A63276)
2026 MACK GRANITE...
2016 Audi A6 AWD Sedan (A64557)
2016 Audi A6 AWD...
2007 TORO 3300-D CART (A66091)
2007 TORO 3300-D...
2003 VOLVO G720B MOTOR GRADER (A66091)
2003 VOLVO G720B...
