Long time lurker, here for log splitter help
   / Long time lurker, here for log splitter help #1
norbert77
Highgate, intario
2012 Deere 325
Good afternoon gentlemen, after years of lurking and finding good info I had to come in and ask for some help. I am building a prototype press kind of like a post splitter,
But it will be vertical. Shop roof clears it's good.
So H-beam a 4" bore cylinder at 3000psi, about 18.8 tons of pressure, or 20 for easy math, but I need 9' of travel on a 10" H-beam, but i don't see very many post splitters to borrow design ideas from, what sort of H beam should I use? How far would a 6" w25 go before bending, should I go to an 8"?
Thanks in advance
   / Long time lurker, here for log splitter help #2
That's a very long span compared to common log splitters... Gonna need a massive beam/support to minimize deflection.
   / Long time lurker, here for log splitter help #3
You have a 4ā€ bore cylinder with 9’ of stroke ?? Never seen such a long skinny hydraulic cylinder . It would be about 20’ high, extended vertical, and need a rod almost the full 4ā€ diameter.
   / Long time lurker, here for log splitter help #4
I would box the beam as well to keep it from twisting. I bought a splitter for my Ditch Witch mini track loader that is boxed. Heavy indeed but built to last !
I did see one exactly what I wanted, there is longer. But to be fair 6ft is more realistic.
Yes, and to complicate things, I want the cylinder beside the beam, not on the far end, it will be more compact
   / Long time lurker, here for log splitter help #6
That one you attached is 25’ long, extended ( tall in your case).
It uses a hollow rod, which makes sense since the rod diameter is such a high percentage of the diameter.
640lb shipping weight 😁
   / Long time lurker, here for log splitter help #7
You still will need a height appropriately a little more than 2x your cylinder stroke length
   / Long time lurker, here for log splitter help #8
There's probably a good reason for that. It'd be cheaper and easier to build a basic bandsaw mill to do this and it'd be a proven design.
Towable Tank (A59228)
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
3015 (A56857)
3015 (A56857)
Kubota M5-111 (A53317)
