Long time lurker, here for log splitter help
/ Long time lurker, here for log splitter help #1
norbert77
Highgate, intario
2012 Deere 325
Good afternoon gentlemen, after years of lurking and finding good info I had to come in and ask for some help. I am building a prototype press kind of like a post splitter,
But it will be vertical. Shop roof clears it's good.
So H-beam a 4" bore cylinder at 3000psi, about 18.8 tons of pressure, or 20 for easy math, but I need 9' of travel on a 10" H-beam, but i don't see very many post splitters to borrow design ideas from, what sort of H beam should I use? How far would a 6" w25 go before bending, should I go to an 8"?
Thanks in advance
/ Long time lurker, here for log splitter help #2
That's a very long span compared to common log splitters... Gonna need a massive beam/support to minimize deflection.
/ Long time lurker, here for log splitter help #3
You have a 4” bore cylinder with 9’ of stroke ?? Never seen such a long skinny hydraulic cylinder . It would be about 20’ high, extended vertical, and need a rod almost the full 4” diameter.
/ Long time lurker, here for log splitter help #4
I would box the beam as well to keep it from twisting. I bought a splitter for my Ditch Witch mini track loader that is boxed. Heavy indeed but built to last !
I did see one exactly what I wanted, there is longer. But to be fair 6ft is more realistic.
Yes, and to complicate things, I want the cylinder beside the beam, not on the far end, it will be more compact
/ Long time lurker, here for log splitter help #6
That one you attached is 25’ long, extended ( tall in your case).
It uses a hollow rod, which makes sense since the rod diameter is such a high percentage of the diameter.
640lb shipping weight 😁
/ Long time lurker, here for log splitter help #7
You still will need a height appropriately a little more than 2x your cylinder stroke length
/ Long time lurker, here for log splitter help #8
There's probably a good reason for that. It'd be cheaper and easier to build a basic bandsaw mill to do this and it'd be a proven design.
Gradall no crank no start (A61568)
Gradall no crank...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
YALE FORKLIFT (A63291)
2013 Felling 25' x 102 Tag Trailer (A62613)
2013 Felling 25' x...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2025 JMR 72in. Hydraulic Dual Cylinder Brush Grapple Skid Steer Attachment (A61572)
2025 JMR 72in...
